Frustrated
10 replies to this topic
  • Longtimeyamahaguy
Posted June 29, 2005 - 10:50 AM
03 WR450, hard to start. Won`t idle unless I have the choke part way on. I have pulled the carb and cleaned it. Flames out the exhaust when it backfires. The bike did the same thing with the stock exhaust on it just not as bad. I just put a FMF pbomb header and powercore sa on it. Header turns cherry red when at idle for about1-2 minutes. I`m beginning to think I should have bought a YZ250 2smoker! I`m going to give this thing 1 more chance with some jetting if that doesn`t work out the first $3100 (without the FMF) will take this thing out of my garage!
  • beezer
Posted June 29, 2005 - 10:55 AM
Its obviously lean.
Stop whining and get a JD kit.
  • Longtimeyamahaguy
Posted June 29, 2005 - 10:58 AM
What is this JD kit?? I bought the bike used and it has a 168 main 48 pilot a few 70`s in it and some red knob hanging down in front of the bowl.
  • jchantzWR400F
Posted June 29, 2005 - 11:19 AM
OK, put the 4-stroke down nice and easy. Step back very slowly. Now turn and walk away immediately...
Seriously, get yourself a JD kit (through the TT store). It comes with instructions and recomendations based upon your riding condition (temperatures and altitude). Oh, and that red knob is the hot-start. If you pull it, it let's air into the carb-helps to start when you dump the bike.
  • Dan_Lorenze
Posted June 29, 2005 - 01:28 PM
It could be that you put on the carb slide-plate on upside down, I've done it, the bike will only run with the choke on when it's upside down.. Check it, and double check it with your manual...
OR-
Something is in the Pilot circut like a grain of sand, make sure that carb is as clean as it could be..
OR-
Check your valves, there's a small chance that the valves might be out of spec...
Change your spark plug....
Sorry, this doesn't sound like a jetting problem.... Even a poorly jetted bike should run with the choke off... A JD kit won't solve this one as you decribed it.. It's something more..
Dan
  • Longtimeyamahaguy
Posted June 29, 2005 - 01:41 PM
Slide plate maybe, plug is good, inside of the carb is/was spotless but there is always that chance of something falling in there. I`ll investigate tomorrow. Valves are just a tad loose on the intake but the exhaust seems good.
  • Stinson
Posted June 29, 2005 - 02:47 PM
3100 hmm, wouldnt mind having another 03.......
  • flatnacker
Posted June 29, 2005 - 02:52 PM
How funny-I dont feel lone anymore, again exactly what my bike is doing!!
And I was thinkin the exact same thing-wish I had stuck with two strokes, so much easier to work on and trouble and maintenance free.....maybe I will change my tune once I have her sorted....
  • hotrunnin-05wr450
Posted June 29, 2005 - 03:01 PM
Yes you will!!
  • RichBaker
Posted June 29, 2005 - 03:11 PM
Then it's lean because the pilot jet is clogged....quit whining, take the carb off and blow compressed air thru all the jets, aftr you remove them!
  • bg10459
Posted June 29, 2005 - 05:35 PM
The red knob is probably the fuel screw, maybe a Zip-ty fuel screw. Does it have numbers 1 thru 4 on it? Check to see that it isn't turned all the way in as this will lean the pilot circuit. try backing it out between 1 and 2 full turns from all the way in. It works opposite from a 2 stroke fuel screw. in is lean, out is rich.
