Boyesen Quick Shot
18 replies to this topic
Poll: Boyesen Quick Shot- Do you like? (43 member(s) have cast votes)
  1. not worth it (13 votes [30.23%] - View)
    Percentage of vote: 30.23%
  2. Voted worth it (15 votes [34.88%] - View)
    Percentage of vote: 34.88%
  3. Voted must obtain it (15 votes [34.88%] - View)
Vote Guests cannot vote
  • atomictom
Posted June 26, 2005 - 09:00 PM
Has anyone tried the quick shot on thier '04 450? If you have is it good, great, unbelievable or what? :) :)
  • CISCO
Posted June 30, 2005 - 01:46 PM
Ive installed them on an 05 only, not an 04...and its a must have IMO
  • StreetbikePimp
Posted July 01, 2005 - 08:30 AM
For $100!!! Not a must have in my book when there are cheaper mods out there to produce the same result.
  • Dolce_Grappa
Posted July 01, 2005 - 09:13 AM
Can you explain what mods are cheaper, that produce the same results? I haven't bought one, but I'm curious on what mods are out there for and 03-05 YZ-450.
  • vantolr
Posted July 01, 2005 - 11:41 AM
I'm not sure about how much difference it will make with a 450, but I'm pretty impressed with it on my 250F. I have no regrets installing it and think it improved my performance.....
  • flatnacker
Posted July 03, 2005 - 09:09 PM
If you only 'think' it helped is it really worth it???
  • yasotay1
Posted July 04, 2005 - 08:32 PM
If you look at the stock acc. pump cover the ports are set to low. Therefore when the diaphram pushes the gas out there is a small pocket of air it has to push out first causing that hesitation in some bikes with the FCR carb. The Quickshot has the ports drilled at the absolute highest point allowing the the cover the fill completely and now all you get is gas when you wick the throttle. I've put it on my 426 and CRF450. It's definitely going on my new 525exc when I get it. :)
  • StreetbikePimp
Posted July 04, 2005 - 09:39 PM
You can buy different diaphrams for the AC pump to get rid of the "bog", or you can buy smaller leak jets or if you're really cheap, just soder the hole in your stock leak jet.
Do a search for Off Idle Bog and you'll get answers on how to fix what the "Quick Shot" is made to fix. Or read through www.thumperfaq.com . They have a section on AC pump mods that are alot cheaper then dropping a $100 for the "Quick Shot".
  • Endurordr
Posted July 06, 2005 - 08:59 PM
I'd buy it again. I love it.
  • Tab812
Posted July 07, 2005 - 09:22 PM
I own a 03 wr450 and have the Quick Shot and a #40 Leak Jet and I still have the BOG.......
It has left we wondering why I spent the $$$$.
  • DIRT ROOSTER
Posted July 10, 2005 - 06:13 PM
I installed on my '02 crf450 and have a hell of a time getting the air screw adjusted correctly. I have it almost all the way in and now it is running right. It took some serious time to get it right. good luck. I had to take the stock settings and throw them out the window and just had to play with it.
  • WGP
Posted October 03, 2005 - 02:16 PM
So are these still recommended on the 05 WR 450??
Need more throttle response down low.
  • yz250ftony
Posted October 03, 2005 - 02:20 PM
I have one on the YZ, still adjusting the air screw.
  • vantolr
Posted October 03, 2005 - 03:36 PM
In combination with good jetting, i.e., JD kit, I noticed a good increase in throttle response, bog reduction and overall improved performance. I'd rate it a 8 out of 10 in terms of must have mods.
:banghead:
  • joe_hru5656
Posted October 03, 2005 - 03:48 PM
What is this Quick Shot. What does it do.
  • bg10459
Posted October 03, 2005 - 05:12 PM
:banghead:
I agree. AFTER getting the bike tuned real good, adding it will make it just a bit better.
  • ShadyatBest
Posted October 03, 2005 - 07:53 PM
i will sell you mine for 60 bucks, im taking it off during the next tear down
  • WGP
Posted October 04, 2005 - 06:22 AM
E-Mail me if you want to sell it!
Why are you taking it off?
  • johnnyghia
Posted October 04, 2005 - 06:52 AM
Installed one on my 03 yz, cant say it made a damn bit of difference. Waste of me hard earned cask. :banghead:
