Coolant questions - NPG and others
12 replies to this topic
  • minion
Posted June 25, 2005 - 01:49 PM
Anyone here, besides ncmountainman run Evans' NPG coolant? I noticed that their website shows three different versions: NPG, NPG+, and NPG-R. I couldn't find anything on their site about the NPG-R stuff though.
nc, any concerns about corrorison damage? Their site talks about sealing off the system, because it'll absorb moisture from the atmosphere. What happens if the system pulls fluid from the overflow back into the radiator? Isn't the overflow vented, to allow room for the boilover to flow back there? With no corrision additives, I'd think it'd be a concern, but if I knew, I wouldn't be here, asking questions. :)
I've had one boil over on my wr450 - it was 90 outside, and it was slow, technical stuff. Right now, its 95 outside, and its supposed to be close to that all week. :) So, that prompted me to do some coolant research. I'm skeptical of stuff that you add to your oil to keep the bike cooler - I'd rather leave that job to the radiator, and let oil do what oil does - lube the engine.
What about stuff like engine-ice, and water-wetter? Any experience with those products?
Also, does anyone have those carbon-fiber air-intake-shroud-thingies installed?
http://www.rockymoun...tv?pid=00085162
Do those make a difference?
Thanks for the info!
M.
  • Indy_WR450
Posted June 26, 2005 - 12:52 PM
NPG-R and the overflow bottle to allow for expansion. I have not seen any issues yet. I think the overflow bottle is sealed tight with the cap. :)
  • Gadsen
Posted June 26, 2005 - 03:38 PM
OK, NC MM calls me a sissy because I run pink coolant! :D I use Toyotas (hey, get a killer deal on it) SLLC also know as "super long life coolant". It contains no silicates or borates, its premixed and they do not want you to use tap water or add any water for that matter. So I suspect its distilled etc. Its designed for aluminum engines, and engineered to go 90K on a factory fill, 60K there after. Of ocurse, I change it every year on my bikes. and if it's good enough for those Yamaha heads on Toyotas, it has to be good enough for Yamaha heads on Yamahas! :) It comes in a 1 gallon container just like any other coolant, but it will have a gold cap on it. Toyota also sells LLC (long life coolant) which has a red cap and is not premixed. I would only use the SLLC, so make sure you freindly Toyota parts guy sells you the correct stuff with the gold cap. It will also mention on the front its 50/50 too. :)
  • minion
Posted June 26, 2005 - 05:44 PM
Indy,
Whats the difference between NPG-R and NPG? I see you can buy all three (NPG+, NPG, NPG-R) from their website, but they say nothing about NPG-R.
How long have you been running it, and did you switch to it because you were boiling over?
M.
  • Indy_WR450
Posted June 26, 2005 - 06:03 PM
The "R" in NPG-R stands for racing version with reduced viscosity for higher flow rates and less cavitation! :)
General Info:
EVANS lifetime, corrosion free, WATERLESS engine coolants have been proven on professional race circuits and private multi million dollar test tracks, exotic engine dynomometers, and in competition with virtually every major sanctioned body of racing including FORMULA 1, NASCAR, NHRA, SCCA, IMSA, IRL, Grand American, NMCA, ARCA, AMA, WERA, American Lemans, SCORE Off Road, World Rally up, and numerous Boat Racing Venues.
Run Faster - Run Better - Never Overheat!
NPG-R is specifically formulated to handle the extreme conditions of racing and high performance automotive, marine and motorcycle applications. The reduced viscosity of NPG-R makes it more compatible with small tube copper-brass radiators while providing the superior cooling of Evans Waterless Coolants. Although NPG-R is safe for all metals and contains no water, an annual coolant change is suggested for racing vehicles. For maximum corrosion protection, high performance street driven vehicles running NPG-R should change coolant every other year
Evans NPG Coolant will transfer 27.5% more heat energy than water in your race engine, due to NPG's molar heat of vaporization and high saturation temperature.
THE BENEFITS OF EVANS NPG COOLANT FOR RACE CAR ENGINES
Increases Power
Extends cooling performance
Improves durability
Provides low, or no-pressure system
Protects from boil-over
Permits increased compression without detonation
Permits more spark without detonation
Eliminates system scaling and reduces corrosion
Permits use of a smaller radiator
Permits smaller frontal openings to improve aerodynamics
Eliminates pump cavitation
Prolongs hose life
  • clark4131
Posted June 26, 2005 - 07:40 PM
I'm running Engine Ice right now and have had no issues thus far. However, I'd like to give the NPG a try when it comes time to change it out. How important is it to flush the system with their prep fluid? Can I just do a regular water flush and go from there? Gracias...SC
  • thumper victim
Posted June 26, 2005 - 07:41 PM
I ride out here on the edge of the mojave desert in the piute mountain area. we ride some of the nastiest single track there is. every coolant has puked out everywhere. i'm running npg+ now and have zero over heating problems. the only problem now is knowing when to stop,before when coolant started steaming i knew to stop & let the bike recvr/cool down. make sure you also get the prep fluid for small engines as recommended by evans,a gallon is enough for two bikes,so you can sell it to a riding buddy to offset the cost. it's kind of expensive,but,well worth it. :)
  • ncmountainman
Posted June 27, 2005 - 09:10 AM
minion,i would reccomend the npg-r as indy stated its thinner for better flow,the r also has a higher boiling point (400 as compared to 375) the overflow tank is not needed,the npg-r does expand a little more than 50/50 but it finds a happy spot about a 1/2" below full and just stays there. the tank is just unnescesary weight :) there is no corrosion from water as there is none,and they say its superior for lubricating the pump. hey toyotie that pink stuff will still boil out at 250-275 :D and if i'm in a situation where that happens, its better to have coolant circulating in a hot motor than to have it circulating to the ground :)
  • Gadsen
Posted June 27, 2005 - 10:51 AM
...hey toyotie that pink stuff will still boil out at 250-275 :D and if i'm in a situation where that happens, its better to have coolant circulating in a hot motor than to have it circulating to the ground :)
I have never had it boil out. I can see my overflow level rising indicating things getting a little warmer. But never more than a few inches. NC, your too slow of a rider, not getting enough air flow across those radiators. :D :) Just funning with ya, I know your a hot dogger in the trails. :D
  • 02WR426Cali
Posted June 27, 2005 - 05:11 PM
So you have to buy that prep crap too? Are you sure?
  • Indy_WR450
Posted June 27, 2005 - 07:38 PM
You can flush it with rubbing alcohol and it will eliminate any water! You need to flush the system with a non water based fluid. I used cheap 99% Isopropyl Alcohol for $3.50 cost. :)
  • 02WR426Cali
Posted June 28, 2005 - 06:08 AM
How do you get all of the rubbing alcohol out after you flush it?
  • Indy_WR450
Posted June 28, 2005 - 07:57 AM
Drain it out at the pump and then just leave it open to the air and any remaining drops will evaporate quickly! :)
