CRF 50 oil change question
9 replies to this topic
  • pheath1
Posted June 23, 2005 - 07:41 PM
when you change the oil on the CRF 50 do you drain both plugs on bottom, and what is capacity to refill oil?
  • tmtex
Posted June 23, 2005 - 07:43 PM
Both plugs ????????
  • pheath1
Posted June 23, 2005 - 07:47 PM
yes, one drain plug under the tranny on left side and the other on the right
  • five0addict
Posted June 23, 2005 - 08:21 PM
right only. 650-700ml, lean the bike and pick up the front tire to drain the oil out the head.
  • limekyle19
Posted June 24, 2005 - 05:39 AM
so you pull both plugs and let the oil drain then put it them back in and refill? I thought u just pull the one were the skid plate isnt blocking?
  • CRF50Racer
Posted June 24, 2005 - 11:17 AM
i'll have to try that next time, how much oil is usually in there? will it hurt if you dont drain it?
  • FXSTCHIEF
Posted June 24, 2005 - 07:24 PM
I think the plug on the left side you are referring to is the cam chain tensioner plug. You DO NOT want to pull that one out to drain the oil.
Drain the oil from the larger plug on the bottom. As far as raising the bike up to empty the head :) I will have to try that one!
  • strandman
Posted June 24, 2005 - 08:23 PM
That's correct. I just did my son's crf 50 a few days ago. It's the larger of the two plugs. I think its a 1/2 inch socket. When you fill with oil, stop once in a while and check the level with the little dip stick, so you know its not over filled. :)
  • five0addict
Posted June 25, 2005 - 10:16 AM
17mm, no standard bolts on the 50 :)
i try to do a complete drain on my bike, get as much dirty oil out as possible. 650ml will be center of the dipstick if you do it this way and 700 will be up to the top of the xhatch. to get an accurate measurement start the bike after you change the oil, idle for 30 seconds, shutoff and check the level again.
  • CRFiddyRyder
Posted June 25, 2005 - 03:30 PM
the other bolt is the cam chain tentioner :)
Pit bike in the making... by the-new-kid
Dirt Bike   Special Interest Forums   Pit Bikes
  • 3 replies
Honda CRF70F 2012 by ThumperTalk
Honda CRF70F 2012
  • 0 reviews
Crf50/ttr90 parts on a 2006 pw80? by Mx1012
  • 0 replies
Honda CRF50F 2016 by Chris.GVS
Honda CRF50F 2016
  • 0 reviews
Honda CRF70F 2011 by ThumperTalk
Honda CRF70F 2011
  • 2 reviews
  • Last review by CB rides
  • On December 01, 2015
