Oil For Wet Sump
6 replies to this topic
  • racerx573
Posted June 23, 2005 - 10:45 AM
I am sponsored by Bel-Ray this year.. do you think a thicker oil would be better for the wet sump? I am running this engine in a quad chassis.. It is an '01 426.
I don't know if I should go with the 10-40 or the 20-50. It is their Thumper 4-Stroke Race Oil
Posted June 23, 2005 - 04:19 PM
First, let me say that converting from the clearly superior dry sump to a wet sump is a bad idea. Perhaps especially so in a quad.
But since it is that way, I think that I would be prone to use the heavier oil recommended for the temperature range because the oil is going to be hotter than it would have been in a dry sump system.
  • sirthumpalot
Posted June 23, 2005 - 06:07 PM
To elaborate on the above; go back to a dry sump if you can. The extra oil capacity should help with durability, especially with the extra load that a quad is going to put on the motor. If you stay a wet sump I would say follow the manual in regards to viscosity for the temps that you ride in, but be sure to change it very very frequently.
  • Ga426owner
Posted June 23, 2005 - 06:25 PM
Wet sump = oil change every hour of operation or after each race/each practice etc... according to DRD....... :)
  • racerx573
Posted June 24, 2005 - 01:25 AM
I went with the wet sump to save space on the quad chassis. The oil tank would have been a squeeze for space with all the lines, and finding a place to mount the tank.. Too late to go back, unless I wann get mounts welded on, and then have to re-powdercoat. I planned on changing the oil every race. I got a good deal on their oil, so I should be set for changing it as often as I need. Around here the weather gets to about 85 on the warmest days. The only times I'd be above 90 would be if I went to an out of state national like Loretta's. I ordered their 20-50. The quad itself is pretty light.. it rings in at about 350 wet. I also have a high capacity radiator for it, and some inline coolers, so keeping it cool, should be pretty easy.
Here is the baby herself..
Before stickers & graphics..
  • sirthumpalot
Posted June 24, 2005 - 05:23 AM
Looks like you're set. Have fun and good luck!
  • MotoGoalie
Posted June 24, 2005 - 08:02 AM
I use the Bel Ray 20-50 and have had no problems. Nice looking quad. Go own some Honda motors with that now. :)
