TPS question....
3 replies to this topic
  • radish150
Posted June 20, 2005 - 10:03 PM
I took my carb out to re jet, and of course the TPS was removed to cook the carb. So, whats this thing all about on 99 400? Do I need it? Can I chop it? Or, do i have to go thru a painfull process to get it set properly again?
thanx yall
Mark...
  • MattyH
Posted July 14, 2005 - 08:18 AM
the tps is linked in no small way to your cdi. cut the tps and you'll probably end up with a large blue motorcycle shaped paperweight
  • Chas_M
Posted July 14, 2005 - 01:30 PM
The TPS increases part throttle advance. On my KTM 525 EXC, I played around with adjusting the TPS and even disconnecting it. The results were, at least by seat of the pants, no discernable differences at all.
  • curveball323
Posted July 01, 2009 - 07:24 AM
Chas M... you ARE SPEAKING TRUTH MY FRIEND!! I disconnected mine yesterday and my problems went away and I have MoRE POWER now that the stutter is gone because of the TPS. I would however like to adjust the TPS so i get that last little bit of power. if anyone knows how to adjust it right let me know
