Flywheels WR & YZ interchangeable?
3 replies to this topic
  • Robert_Brazil
Posted June 19, 2005 - 03:43 PM
Can anyone tell me if the flywheels of both bikes (same year) are interchangeable? I know the WR is heavier, yet that´s the whole idea. If not, what´s a good aftermarket flywheel weight addition to make a YZ450 stall less technical tracks. Does the rekluse solve this?
  • ArmyGuy
Posted June 19, 2005 - 05:57 PM
I can guarantee they are interchangeable on a 99 YZ400. i put one on mine for the lighting kit to be street legal. I cant see any reason why a 450 would be any different. you will have to buy both the ignition coil and the flywheel though. it'll run you about 275 for both pieces.
A rekluse clutch will help with the stalling part as the clutch automatically engages as you roll off the gas/slow down. Id still recommend a heavier flywheel. it made a HUGE difference on my 400 and it isnt even that much heavier.
Dan
  • ncmountainman
Posted June 19, 2005 - 06:27 PM
they are not interchangeable 03-05,at all. the cases are different for the wr stator, even the crank taper is different :)
Posted June 19, 2005 - 07:59 PM
'03 and up WR's flip the flywheel around "inside out" so they can use the back of it for the drive for the e-start. Nothing under the two ignition covers, including the covers, will interchange.
  • 0 replies
  • Hot  113 replies
  • 10 replies
  • Hot  47 replies
