02 Wr426, Ignition trick, which wire?
6 replies to this topic
  • krasd
Posted June 19, 2005 - 12:50 PM
I have an 2002 WR426, I'd like to do the ignition trick that makes the CDI read the YZ ignition curve, I know on the 2004 Wr450 the wire is grey and is located in the six point connector, but for the 2002 Wr426 there is not a grey wire in that six point connector, so I'm a little lost and need some help thanks.
  • wrkaholic
Posted June 19, 2005 - 01:57 PM
I have the same bike, mine was a grey wire. That is wierd that you do not have one. What are the colors of all your wires in the connector just under the front of your tank?
  • HamBonE_23
Posted June 19, 2005 - 03:25 PM
Not to bust in on your thread but you inspired me to do the same thing. I looked at all the wires and from the input that I received in the past, it was my understanding that the grey wire was intermixed with multiple other wires. On my 01 WR426 I was able to find a grey wire but it is in a plug with one other. It just seems wrong that if you have a two prong plug that it would be bad to unplug one of the wires. Here's a pic of the wires of my bikes wires. Is you bike the same?
http://i22.photobuck...23/MVC-003S.jpg
  • HamBonE_23
Posted June 19, 2005 - 03:26 PM
let me know if you need a better pic of it.
  • krasd
Posted June 19, 2005 - 04:00 PM
Yes you are right, I looked for a second time at the six point connecter and there is a dark grey wire on the bottom side of the connecter only and I believe it changes to a black and yellow wire on the top side of the connecter, is this the correct wire? other than that the only grey wire I see is the one in a two point connecter. Thanks for time and help.
  • krasd
Posted June 19, 2005 - 04:46 PM
These are the colors that I have closest to the CDI under the tank: red, green, black with a yellow stripe, white, browen, and pink. The bottom connector colors are all the same except I have a dark grey wire that connects into the black and yellow stripe wire on the topside. Hope this helps thanks.
  • krasd
Posted June 19, 2005 - 05:04 PM
Yep, That is the same connector and the only grey wire I see in my six point plug is on the bottom side, which is a dark grey wire that connects into on the top side of the plug with a black and yellow striped wire. The clearest grey wire I have is also the two prong connector. I have the newest issue of Dirt Rider Mag and they cut there grey wire out of the six point connector and it was a light grey like the two prong connector, but that was an 04 Wr450.
