16T with a 50T Rear?
15 replies to this topic
  • Eliems
Posted June 18, 2005 - 05:17 PM
Does anyone know if a 16 tooth front sprocket will work with a stock 50T rear sprocket and a stock chain or would the chain be too short?
Thanks!
  • black_n_blue_thumper
Posted June 18, 2005 - 08:13 PM
I have no idea, but why do you want to do that? :) Do you run extremely high speeds or what. I just put a 13T on and that was one of the best mods I have made. :)
  • rushfan
Posted June 18, 2005 - 08:32 PM
Hey bnbt. 14 teeth is the stock front, right? I went to a 50t in the rear and but had to get a longer chain. Gives me a little more grunt in the steep stuff. Does going to a 13t in the front do the same thing as I did?
  • rushfan
Posted June 18, 2005 - 08:37 PM
Oh yeah, did you take some pics of your rad guards? :)
  • Indy_WR450
Posted June 18, 2005 - 09:40 PM
You will need to add at least one link. Two ideally. :)
  • Eliems
Posted June 18, 2005 - 11:02 PM
"I have no idea, but why do you want to do that? Do you run extremely high speeds or what."
I have plates on my 450 so I want a bit more top end. 50 MPH and she is reving quite high where a 16 tooth would add 15 MPH to that while 1st would still have plenty of torque. Still, if I have to mess with the chain at 16T I think I will return it and go with a 15T front sprocket. 50 is stock for the rear.
You guys are sure the chain won't wrap around 16/50 ?
  • Indy_WR450
Posted June 19, 2005 - 05:05 AM
Only if you like the rear wheel jammed against the swing arm!
Buy a 116 link 520 o-ring chain! :)
  • Dan_Lorenze
Posted June 19, 2005 - 07:13 AM
I'm pretty sure a 16 won't fit.... :) I use a 15 from time to time and boy it's a tight fit, I don't think a 16 would fit... You best option might be a 15/48, if your bikes full uncorked with a nice exhaust you go over 100mph.
Dan :)
  • TwoBobRob
Posted June 19, 2005 - 09:10 AM
I ended up going down the two chain route and running 14/50 offroad and 15/46 on road with SM wheels.
I think I'm with the other fella, I'm sure a 16t won't actually fit........ :)
  • cdonowho
Posted June 19, 2005 - 03:16 PM
I run quite a bit of highway with a 15/48 using the stock chain. It gets a little buzzy over 65, but it is a dirt bike after all. I don't think you would want to go much higher than that, unless you're ONLY riding on pavement. I'm almost positive a 16 won't fit anyway- the 15 is REAL close.
  • HamBonE_23
Posted June 19, 2005 - 03:32 PM
I had a 15/50 with the stock chain, it worked and I still had some adjusting room for the rear tire.
  • 99wr400
Posted June 19, 2005 - 08:45 PM
That gearing sounds wayyy too high. I run 13/52, and I Don't need any higher gearing, although my bike will pull a 5th gear wheely. But I just trail ride, and rarely get out of 3rd gear. You should try the 15 tooth front before you try the 16.
Posted June 19, 2005 - 09:42 PM
I think stock is 14/48 They told me going down one on the front is like going up 3 on the rear. So if that is correct, yes it would be pretty close to what you did. Idleing and real slow speeds thru the technicle stuff and pulling real steep hills when you cant get a good run at them is way way easier. I went out yesterday and purposely(sp) rode some stuff that I have had a hard time with in the past, boy oh boy what an awesome improvement. :) I rarely see 80mph so losing a little top end was no big deal to me. And no, I am a big slacker and didnt snap the pics this weekend. :) I will try to real soon though. :D
  • rushfan
Posted June 20, 2005 - 04:43 AM
So if I'm currently at 14/50 with a 116 link chain, I can go to a 13/50 with the same chain, right? :)
  • jchantzWR400F
Posted June 20, 2005 - 06:43 AM
I went with a 15-44 combo for a while. It worked very well. 65 mph and purring. I did have to take 2 links out of the chain. And as others have said, the 16 won't fit the front.
  • cdonowho
Posted June 20, 2005 - 07:03 AM
Yes, 13/50 will work with stock chain. :)
