Engine noise
4 replies to this topic
  • tnl
Posted June 12, 2005 - 07:18 PM
Was out today riding for a ahort while and ran full speed in 4th gear on the street. At about half throttle in 4th gear I hear a unfamiliar sound coming from the engine area. Sounded like a loose washer rattling on a shaft? I have noticed this sound at the track last month in 3rd also. I've opened it up full throttle couple of times in 4th and pushed other gears to red line so I know the engine has been ridden a little. My 05, 450 has about 25 hours on it and I have not yet checked the valve clearances on it yet. Does this sound like a valve issue? I'm a little cautious about checking the valves since this is my first time doing this kind of procedure. Ya know; "don't fix it if it aint broke"
Thanks!
  • undrdog
Posted June 13, 2005 - 06:02 AM
Without hearing what the bike sounds like its a little hard to tell. If I were you, I would check the valve clearance. Just take your time, its not that hard to do.
  • lanham
Posted June 13, 2005 - 07:03 AM
I have the same noise. Let me know if you figure it out. Since the 2006 isn't available until Nov., I may take my bike in for a check up just so I don't blow it up.
  • Rick_Graham
Posted June 13, 2005 - 01:44 PM
Adjust your chain, it may be slapping your swingarm and fooling you into thinking it's more serious than it really is.
  • tnl
Posted September 15, 2007 - 06:23 PM
Found out today during a ride that the noise is coming from the kickstarter while it is in the resting position. I didn't look at it in the garage yet but I'm sure it's an easy fix.
