2006 YZ450F 5 speed yellow or blue?
99 replies to this topic
  • mxmark
Posted June 12, 2005 - 05:47 PM
I just got a call from my Boss and he asked me do I want yellow or Blue? 5 speed, aluminum frame. I guess Mike Bell got to do the honors of the into. I don't have all the details because I am going to Star west to go moto. My 2004 Husqvarna CR125 and my 1981 YZ465. I hope I did not rush anything. I had a 1998 yz400f and a 2003 YZ450F I can't wait until they get here. Go Yamaha 50 years! Thanks Mark
Go to www.yamaha-motor.com after 9pm tonight I think they are on there.
  • ThumperKid250F
Posted June 12, 2005 - 05:53 PM
yellow would be sick...
  • Butta
Posted June 12, 2005 - 05:58 PM
2 hours, 5 minutes, and counting......
  • aedwards07
Posted June 12, 2005 - 06:55 PM
Yep.Yellow and blue.I cant decide.
BTW 1hr 5 minutes.
  • Dick Falcon
Posted June 12, 2005 - 07:31 PM
29min!!
  • DPW
Posted June 12, 2005 - 07:42 PM
Good to see I'm not the only goofball up waiting... ;-)
  • saucebox
Posted June 12, 2005 - 07:59 PM
11:00 according to my clock and i'm not seeing an updated page yet
  • saucebox
Posted June 12, 2005 - 08:00 PM
damn.. guess it took till 11:01
  • NAFLASH
Ahhhhh Aluminum!!!! Muhahahahahahhahaa
  • saucebox
Posted June 12, 2005 - 08:04 PM
they still list it as 220 lbs dry.. thats what my 04 model was rated at when i got it
  • SkyRaider
Posted June 12, 2005 - 08:05 PM
5-speed.
  • WheelsUp
Ouch. $200 more for yellow?
Looks sweet.
I noticed only a few minor changes on the WR250F... looks like they added a enduro computer and made it California-Green, which means we'll be needing a Lowedog AIS removal kit and a JD kit to get the adjustable needle back.
No aluminum frame for WR.
  • NAFLASH
Posted June 12, 2005 - 08:08 PM
note the color of the clamps, some sort of coating????
  • Butta
Posted June 12, 2005 - 08:10 PM
Don't believe the spec's page.....it still lists it as a 4 speed, which is contradicted in the Features and Benefits page...
  • SkyRaider
Posted June 12, 2005 - 08:12 PM
New for 2006:
* New, close-ratio five-speed transmission provides more performance in a wider range of riding environments.
* All-new aluminum frame is an extensively tested combination of castings, extrusions, forgings and aluminum tubing — all carefully put together to produce a chassis that takes legendary YZ handling to the next level.
* Speed-Sensitive System 48mm Kayaba fork move the TCV (transfer control valves) above the fork springs, so that damping force is now controlled by piston speed; that prevents mid-stroke damping force changes, for a smoother, more precise ride.
* Titanium-sprung four-way adjustable rear shock rod diameter is 2mm bigger. New, Kashima coating reduces friction for fantastic compliance and great handling.
* Carburetion and exhaust changes let the 449cc four-stroke breathe free for even greater power production.
* Changing the cylinder head angle and moving the dry sump oil tank inside the front of the crankcase improves overall balance and handling and eliminates external oil lines.
* Redesigned piston, crankshaft and connecting rod for increased performance and durability. An oil jet now directs oil at the piston bottom for increased cooling.
  • NAFLASH
titanium spring? "Titanium-sprung four-way adjustable rear shock"
  • DPW
Posted June 12, 2005 - 08:13 PM
Stock ProTapers
  • NAFLASH
oil tank is in front of the motor i guess molded into the case
  • DPW
Posted June 12, 2005 - 08:16 PM
Release Nov '05...hmm
  • NAFLASH
diff CDI this year, hopefully changed for the better
  • Hot  38 replies
  • On January 15, 2017
  • 10 replies
  • Hot  36 replies
