Engine ice/Water wetter
5 replies to this topic
  • racer8
Posted June 11, 2005 - 08:33 PM
Will either one help the eng run cooler or is it
for a existing over heating problem?
I don`t have a over heating problem,,,
but if it will lowwer the temp,I`ll
try it.
Which is one recomended?
Thx.
  • B86_Racer
Posted June 11, 2005 - 08:59 PM
Either one will lower the temp of your bike but the engine ice must be used by itself, and you must flush your system before you add the engine ice. With the water wetter, you must flush your system but you add water wetter to distilled water, and don't run it by itself. Correct me if I am wrong.
  • ncmountainman
Posted June 11, 2005 - 11:19 PM
water wetter worked for me helping to keep the engine ice in the engine,just use it in the same ratio recomended for water. fww engine ice might be good for MX but i couldn't keep it in the bike on tight HS,the only thing i've found that will not spew,is evans npg-r :) ya,ya been down the road before :) evans npg-r(which is ethylene glycol based) does actually have less heat transfer than most water based coolants,BUT it stays in the bike when needed most. so what that translates to is , when your in a mud bog and screamin' the bike just to keep a walkin' pace,the evans is still circulatin'round the cylinder,whereas the engine ice is pollutin' the atmosphere :D
  • HyBridYZ426
Posted June 12, 2005 - 06:43 AM
there was a page some time back where they tested the 3 different ones...water wetter, royal purple & engine ice....all 3 worked real good...the redline water wetter was on top...the only bad thing about the red line is theres no lube for the water pump.
  • DigilubeJay
Posted June 12, 2005 - 06:03 PM
Water Wetter is only a coolant addidtive, not a fully formulated coolant like Engine Ice.
You can add a surfactant (Water Wetter) to any sort of coolant and it can help the fluid to transfer heat better by changing the surface tension of the fluid.
I'm a firm believer that a clean water with a surfactant added is the best coolant fluid there is. Just don't forget about winter!
Dave claims that Engine Ice doesn't need a surfactant, as the propylene glycol takes care of the surface tension.
Water Wetter in a test against any coolant is apples and oranges..not the same things.
  • HyBridYZ426
Posted June 12, 2005 - 06:24 PM
water wetter is good for me I live in Tampa Fl,....
  • Hot  50 replies
