Hydralic Clutch
1 reply to this topic
  • ShawnC
Posted June 11, 2005 - 07:59 AM
I just purchased a Magura hydralic clutch for my '04 WR450F and I'm not sure on the neutral safety switch connections. Do I need another part, or do you just cut these wires? The Magura owner's manual says to connect the wires to the Magura switch if so provided andif not, then your basically on your own. I purchased the system for the WR450F, so you would have thought the damn thing would have had the switch.....Personally, I would like to eliminate the switch completely. :)
ShawnC
  • Lowedog
Posted June 11, 2005 - 08:09 AM
I just took the wiring on mine and coiled it up behind the headlight and zip tied it in place. Just have to remember it will turn over while in gear with the clutch engaged.
:) Lowedog
