removing the impeller?
2 replies to this topic
  • INJURY_69
Posted June 10, 2005 - 10:16 AM
Was wondering what tool was needed to get this off, does one need a impact wrench? :)
  • ncmountainman
Posted June 10, 2005 - 01:09 PM
if your talkin'bout the water pump, i held the impeller with channel locks. theres not alot of torque on it. just be careful not to ding it up :)
Posted June 10, 2005 - 01:25 PM
:) Yikes! Don't do anything heavy handed to the impeller shaft. You'll snap the drive tab off the inboard end!
You are supposed to remove the case and hold the inside end with a wrench on a pair of flats provided for the purpose. Then, you can inspect the shaft for a wear groove under the seal. You'll want to do this if you're removing it to replace a seal. If you're just upgrading the impeller, you could do it by holding the impeller as suggested, but you'll want to be very careful about installing your new one.
  • 10 replies
  • On January 15, 2017
  • 0 replies
  • Hot  38 replies
  • Hot  47 replies
