Bike stalls when throttle is chopped
7 replies to this topic
  • don87xr600
Posted June 10, 2005 - 07:09 AM
My bike will idle all day but stalls when the throttle is chopped at speed. Any suggestions to correct this?
  • jws
Posted June 10, 2005 - 07:18 AM
Dont chop - just nice and easy roll on :) This was the one reason I switched over to a pumper carb. I had no other problems with my stock carb except for the built in honda kill switch when i would wack the throttle :D I have herd if you fatten up the pilot that it helps :)
  • ponq
Posted June 10, 2005 - 07:39 AM
So in other words it's a lean condition.
I have an edelbrock pumper and if it is not tuned correctly it will do the same thing.
  • don87xr600
Posted June 10, 2005 - 07:42 AM
I think judging by the puddle of air filter oil on the floor I've over oiled my filter, will this cause the stalling?
  • jws
Posted June 10, 2005 - 07:47 AM
Yes - if your pump is not set right on the QS it will do the same thing - but when its dialed in it hits hard and you can chop it all you want and it just keeps hitting harder :)
I played around with the jetting on my stock carb all the time trying to get rid of the kill spot on the chop and could never get it :)
good luck :D
  • jws
Posted June 10, 2005 - 07:54 AM
I swiched over to NO TOIL and had the same thing with the oil wanting to leak all over the floor :) didnt think much of it cause the bike still ran fine but after a 100 mile weekend i could see a little dust in my air box. This is not a knock on NO TOIL I just think Iam used to the spectro spray that i have been using its real tacky and I have never had any dust in the box.
Another thing is try turning your idle up just a little that helped on my stock carb :)
  • truck6driver
Posted June 10, 2005 - 10:16 PM
What mods have you done to the carb?
RH
  • don87xr600
Posted June 11, 2005 - 03:33 PM
Problem solved! Insufficient warm-up.
  • 9 replies
  • 3 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  60 replies
  • Hot  186 replies
