2001 yz426 running rough
4 replies to this topic
  • cpeters042
Posted June 09, 2005 - 04:46 AM
My 426 is running terrible. The bike is sputterring (running rough)and it actually backfired when I shut it off the last time I took it out. The rpm's seem to surge while idling (rough,good,rough,good). It seems to get worse the longer the bike runs. I changed the plug and this really didn't help. Everything on the bike is stock (jetting, exhaust etc.) I have done the blue wire mod. The coil lead popped off of the plug cap when I was changing the plug. I put the coil lead back on and everything seems to be ok. I would think that it is a relatively simple problem based on the fact that this happened overnight. Took the bike out and it ran great, the next time I start it I have this. I'd appreciate any help.
  • Cisco5311
Posted June 09, 2005 - 06:59 AM
You might have somthing in your carb. Take it off and clean it, it could just be a piece of grit in one of the jets. Welcome to TT!
  • cpeters042
Posted June 09, 2005 - 09:03 AM
Thanks, glad to be here.
I'm pulling the carb tonight.
  • mkporn
Posted June 09, 2005 - 09:05 AM
If this seem to happen after the cap issue, did you wash the bike after your ride? May have a miss fire happening due to the cap not being securely fastened or water trapped creating a path to ground..... Or the carb.
If it seem to rear it's ugly head after the cap issue I would start there. :)
  • cpeters042
Posted June 13, 2005 - 03:07 AM
Thanks,
Cleaned the carb and the bike is back to normal.
  • Hot  50 replies
  • 10 replies
  • 5 replies
