YZ 400F Engine HELP
10 replies to this topic
  • Barbados-WR
Posted June 08, 2005 - 04:16 PM
Hi guys,my 400 motor was completed today, has std Wiseco piston kit, head rebuilt by Eric Gorr, 2003 yz450 Cam mod , ngk CR8E plug and using 2000 WR Exhaust. Started after couple kicks for first time with choke out. I allowed it to warm up and pushed choke in and it stalled. Restarted easily and i played with throttle a bit allowing it to run a bit over idle rpm, then after about 5 mins i noticed the head pipe was starting to glow so i turned motor off right away. Any ideas what this could be ?
  • Barbados-WR
Posted June 08, 2005 - 04:30 PM
Just did a search , say its NORMAL to glow on idle with choke out ..
Still have the problem with it not idiling when i push the choke in . Any help ?
  • Hick
Posted June 08, 2005 - 07:25 PM
Try turning up the idle speed knob. Then get back to us.
  • Barbados-WR
Posted June 08, 2005 - 07:33 PM
I did that also, turned the knob fully clockwise and no rise in idle. Unless i have the direction wrong?
  • Guest_RIDE_for_RED_*
Posted June 08, 2005 - 07:43 PM
its normal its due to no air flow. Dont worry, yzf250 does it sometimes all the way to mid pipe.
  • Hick
Posted June 08, 2005 - 09:04 PM
No, that is the right way.
I would make sure the idle adjustment is working, it is a simple threaded mechanism that acts as a stop on the throttle pulley.
More likely is your pilot jet (also called slow jet) is clogged. Try clearing it w/ a shot of WD-40 or something.
Try that and get back to us.
Hope this helps.
  • mkporn
Posted June 08, 2005 - 09:18 PM
Your carb is varnished up... Tear it down and make sure all the jets and passages are clear. :)
  • Barbados-WR
Posted June 09, 2005 - 01:42 AM
i'll have carb cleaned 2day .Will post results after. May be the problem as motor was down while for rebuild.
  • Barbados-WR
Posted June 09, 2005 - 04:55 PM
Carb was fully stripped down and all parts cleaned etc...But still very low idle.. Could it be WR pipe with YZ Jetting ?
  • Frostbite
Posted June 10, 2005 - 01:59 PM
The idle screw on the carb does the same thing that twisting the throttle does, it opens the slide. If the idle is not increasing as you turn the idle knob clockwise, then either the knob is backed out so far that it is not making contact with the throttle slide yet, or the cable connection between the knob and the pin that threads into the carb is broken. Start the bike and crank in the idle knob until engine speed increases. You're not changing mixture or carb settings, you're just setting how far the slide will stay open when you let go of the throttle grip.
  • Batman
Posted June 10, 2005 - 02:39 PM
Dont worry about it , thin metal glows when hot ! Quit F-ing around and go ride that thing ...jeez ! A bone stock new bike will do the exact same thing .
  • 0 reviews
  • Hot  47 replies
  • 9 replies
  • 5 replies
