white bros E series on my 650r
13 replies to this topic
  • BIG RED
Posted June 07, 2005 - 07:51 AM
just bought a new white bros E series S bend muffler for my 650r off ebay. i got it for $120 so i will try it anyway , but i was wondering if anyone here has tried it and what they thought of it? my bike is uncorked with a 165 main and a 68s pilot i am at sea level so i set my bike up as rich as recomended for uncorking and it seems fine until i get way up in the mountains its a little hard to start. if anyone has one of these cans how much did you richen your bike?
Thanx
  • BIG RED
Posted June 07, 2005 - 08:08 AM
sorry my main is a 175
  • TimBrp
Posted June 07, 2005 - 08:36 AM
FFEEWWWW... I was like, way LEAN man! They're louder and produce a decent punch in the lower end to midrange. I think the biggest thing you'll notice is the weight savings and sound.
  • qadsan
Posted June 07, 2005 - 11:29 AM
In a magazine pipe shootout a few years ago, I recall the WB E series slip on was the only exhaust to slightly increase the power everywhere as opposed to the other aftermarket systems, some of which actually lost power compared to the stock system with HRC tip. There was also another guy on this board years ago who bought every exhaust system he could get his hands on and sold them all off afterwards and kept the WB E series as his personal choice for durability, tunability and overall performance for 'his' riding needs.
I would guess some of those exhaust systems that didn't test so well years ago may have improved over the years as things are continually changing in this industry, but the WB E series is still probably a very good choice :)
  • Baja Rudy
Posted June 07, 2005 - 01:34 PM
If you are interested I have a NEW set of headers for that pipe. retail is $250 or so. I will sell for $200 plus shipping.
  • sgtmadmax
Posted June 07, 2005 - 01:53 PM
I installed the white Bro E pipe on my pig right after bought it. The bike is alot louder with the pipe but well worth it. As for the weight savings, the stock pipe is build for a tank. I say by putting on the E you are taking off half the weight of the stock pipe. If you haven't put the bigger intake on it you should. With the bigger pipe the motor wants to take in more air. Max :)
  • sixdoubleo
Posted June 07, 2005 - 02:39 PM
I have the E-series also. It made a huge difference. I think I only rode the bike once in stock form. To be honest, my XR has been in the shed for about 2 years now so I couldnt tell you what my jetting is.
I am just now taking an interest in riding again. I'll be pulling it out and probably pulling the carb off to clean it. I'll record what jets I'm using.
I also think I added some plates to the pipe as well.
  • BIG RED
Posted June 08, 2005 - 03:50 PM
thanx alot guys that is what i wanted to here! and yes baja rudy i am interested in your header let me know what make and model it is and i will check it out and see if it is what i want. i was leaning toward the fmf power bomb header
Clint
  • Tber
Posted June 08, 2005 - 05:46 PM
Thanx
you know, you can richen up your bike just by taking disc out of the muffler( it is tunable). The less amount of disc the richer it gets.
  • sixdoubleo
Posted June 10, 2005 - 07:00 AM
Big Red....
I pulled my carb off last night to clean it and while it was apart I recorded my jetting:
Pilot: 68
Main: 175
Slide: J3B
Needle: 53D
Clip: 4th Position (from top)
I'm running 11 plates on the E-series, PLUS the block off plate.
  • Baja Rudy
Posted June 10, 2005 - 07:39 AM
the header ONLY works with the WB e-series pipe!!! this is the header that comes with that pipe from White Brothers. I don't know if it works with any other system/pipe or brand. this is it; the only one that surely works with the e-series.
  • Baja Rudy
Posted June 10, 2005 - 07:46 AM
I'm not sure that the FMF power bomb header works with the WB e-series. FMF, WB, ProCircuit and others usually don't interchange or mate together.
you should call FMF prior to ordering the header.
  • BIG RED
Posted June 10, 2005 - 09:16 AM
Hey sixdoubleo thanx for that! I am running the same jetting but when doing my uncorking i raised my needle to the #2 position. i am at sea level and with a 175 main a 68s pilot and my needle in the #2 position and i think my bike is running near perfectly. i don't know your altitude but you should check with some guy's here and see if your needle is in the rite spot
Thanx
  • sixdoubleo
Posted June 10, 2005 - 12:20 PM
I am in Sacramento California which is at about 100ft elevation. I do my riding at about 800-1000ft elevation. I agree that my needle might be too low, causing too rich of a mixture. I think when I last rode, I was still playing with the jetting. I'm going out Sunday so maybe I'll try dropping it.
  • 3 replies
Washington
  • Hot  32 replies
  • 0 replies
  • 7 replies
  • Hot  60 replies
