Street Leagal Fast and Cheap
27 replies to this topic
  • freestyle250
Posted June 06, 2005 - 05:26 PM
Has anybody come up with a really cheap way to get a 450 street legal? I know where I can get a setup pretty cheap, but im kind of a penny pincher. So if any of you have some advice on what I can do to get this done the cheapest way possible, I'd appreciate it :)
  • extex
Posted June 06, 2005 - 05:37 PM
yzman just posted this for me on the dualsports forum....and if you've read enough of his posts you can be assured he knows what he is talking about! Thanks again yzman:
Hey ExTex. You can get your bike legal way cheeper than the Trick dual sport kit. All you need is the following
Hydraulic brake light switch $15-20 www.bajadesigns.com
Acerbis Mirror $15 www.Rockymountainmc.com
Toggle switch $3 Radiioshack
Some wire and connectors $10 Radiioshack
DOT Kenda Trackmaster tires $75 a pair thru www.Rockymountainmc.com
Honda Kill switch $10 Honda
Radioshack Personal alarm and 9v battery $10 Radioshack
Insurance $50 thru www.bike-line.com
Here is the horn. Just wire the Honda Kill switch to the alarm. Open the alarm up and there are 2 metal tabs with wires on them. cut the metal tabs off and attach the wires to the kill switch. Instant horn.
http://img.photobuck...rn_close_up.jpg
http://img.photobuck...s/horn_assy.jpg
Your rear tailight is already wired for a tailight / brakelight. You just need to splice in and wire in the hydraulic pressure switch. Pretty easy really.
The headlight is a high low bulb. But like the tailight isn't wired. Take the toggle switch and wire it in so you have high/low beam.
That should do you. $140 is way cheeper than any dual sport kit you will find.
  • bfly
Posted June 07, 2005 - 05:19 AM
Hydraulic brake switch
mirror (which is gone now)
bicycle bell
dremel tool
  • farkawi
Posted June 07, 2005 - 06:27 AM
12v horn, dimmer switch with button, used at a local boneyard. $10. Bicycle mirror with flexi-stem from Wal-Mart $5.
  • J_DOGG
Posted June 07, 2005 - 07:00 AM
I went to a mountain bike store and got a good quality left side mirror $5 and squeeze horn $10.... The horn needed to hit a certain decibel and the one I got was rated for the street. It looks like a clown horn... I zip tied it to a bracket already on the bike behind the light of to the left so I can prove to the cops I can squeeze it and still ride. two years of use and it still works. I have only had to replace the mirror once so far, so I keep a spare in my tool box.
Did the tail light with the defuser thing.
Still running 759's (3rd one) and I get a sticker no problem from my shop...
I live in NH the "Live Free or Die" state, so far so good.
  • firezwr426
Posted June 07, 2005 - 11:06 AM
there is a guy from kaysville who sells really clean kits. I have one and I love it. very clean and simple for a just barley legal kit..
http://cgi.ebay.com/...sspagename=WDVW
  • lowry
Posted June 07, 2005 - 11:16 AM
I have that kit too, super easy to install, good directions and it's cheap.
He was nice to deal with too when I had questions.
I also bought a K&S Hi/low beam switch from dennis kirk and those litez 'n bolts for the rear plate.
  • stonewall
Posted June 07, 2005 - 01:04 PM
I have the same kit and K&S switch. Great setup for the money. :)
It's about as bare minimum as you can get and still be legal.
  • Newfoundlander
Posted June 07, 2005 - 05:38 PM
You allready have a battery but this is what i did. This really works been running on my xr 400 since the first of april 10aa nicad rechargeables $10cdn ran in series 12volts. Rectifier from radioshack $4.95cdn.
Here is the wiring diagram i used.
  • freestyle250
Posted June 08, 2005 - 12:56 AM
Thanks Everybody
  • PumpkinHumper
Posted June 30, 2005 - 09:06 AM
yzman just posted this for me on the dualsports forum....and if you've read enough of his posts you can be assured he knows what he is talking about! Thanks again yzman.
Wow an actual compliment from someone. Thats gotta be a 1st... Thanks :)
  • rockieman
Posted June 30, 2005 - 09:33 AM
Here is my cheap and easy way to street legal....
Hydraulic brake light switch $20
Acerbis mirror $20
turn signals extend arm straight for left turn, 90 degrees for right turn :)
Acerbis led tail light $35
insurance $50 for both bikes
license plate ~$50 per bike
Horn gee officer.... it must have fallen off on the last trail
Dunlop 739's but officer..... they are worn down to the DOT specification.
Moral to the story....I have been pulled over numerous times and have never had them ask about the horn or the DOT tires. Here in Colorado....all they want to see is that green plate with white letters on the back.
  • Joe Reitman
Posted August 23, 2005 - 02:20 PM
"Your rear tailight is already wired for a tailight / brakelight. You just need to splice in and wire in the hydraulic pressure switch. Pretty easy really.
The headlight is a high low bulb. But like the tailight isn't wired. Take the toggle switch and wire it in so you have high/low beam."
"I also bought a K&S Hi/low beam switch from dennis kirk"
I am not a wiring guru. Could someone please provide a bit more detail on this? Thanks! :D
  • Joe Reitman
Posted August 23, 2005 - 02:24 PM
Found this but still seeking a bit more instruction, wire color, etc. Thanks.
"Yes, you need the K&S pressure switch (size 10X1.25) and screw it ino the rear master cylinder. Now take the 2 wires from the switch, "T" one side into the power for the running light wire and the other side into the stop wire coming from the original WR tail lamp. Now you will have a stop light, but only with headlamps on."
  • Joe Reitman
Posted August 23, 2005 - 02:25 PM
Found this too- any part #'s on Radio shack item?
"Go to the Baja Designs web site and order the brake switch for the Nissan master cylinder. Very simple install. The stock WR450 light has 3 terminals with the 1157 bulb already installed, so all you need to do is connect the wires. I changed out the stock plug-in connector with a new 3 wire plug-in from Radio Shack to make the connections clean."
  • Joe Reitman
Posted August 23, 2005 - 02:26 PM
Hopefully my final question- license plate light suggestions? Besides LED bolt? Thanks again. :D
  • Joe Reitman
Posted August 23, 2005 - 02:31 PM
Found this too: "ordered from www.4strokesonly.com
Part #44-0077
10X1.25 mm fits most (fits nissin plus others master cylinders) japanese models of on - off road motorcycle and atvs. Head of banjo bolt is 14mm, wire length is 20" long with male bullet connectors."
  • Matty05
Posted August 23, 2005 - 03:16 PM
I'm glad the Australian model is ADR compliant and can get registered straight away. :D
  • RichBaker
Posted August 23, 2005 - 03:42 PM
My hydraulic switch died after 1 1/2 years. I went out and took the Yamaha mechanical switch off my S(treet)L(egal) XR600. It is ~14 years old and works fine....got it cheap from Yamaha dealer, don't recall the part number, but it was 1/2 the price of the hydraulic sw. and lots longer lasting...
You probly don't need DOT tires, I don't have them on mine, but AZ is pretty lenient...
  • Joe Reitman
Posted August 23, 2005 - 06:32 PM
Thanks- the mechanical switch sounds like a great idea. But I am a bit confused about the Yamaha model you mention. Although I will probably end up borrowing one off a friend's XT225 if it will work.
ps- I have DOT legal tires- Dunlop K180's
