Stock 14/49 for the woods
7 replies to this topic
  • 426Hurricane
Posted June 06, 2005 - 01:33 PM
Anyone running stock gearing in the woods? I have an 00 426 and im running 13/49 and i have no complaints in the tight stuff, but on the track and open trails i need a little more pull. The 13/49 was on there when i bought it so i have no idea what the 14/49 would be like. I am ordering a new renthal set this week so just looking for some feedback on this. I was thinking of going with a 14/50 just to pick up a little more since i know +1 in the front= -3 in the back and vice versa, so i thought a 14/50 would be a good compromise. Thanks in advance for your feedback.
  • 00YZ426FMRCD
Posted June 06, 2005 - 02:34 PM
I also have a 00-426. The Stock gearing - 14/49 was just too high for the woods. (Great for the MX track though) I race Harescramble and a little MX and went with a 14/52. Perfect for the woods (Tight woods) but a little too low for MX and open trails. If I had to do it all over again, I think a 14/51 would be ideal for both.
You could always stay with the 14/49 and order and extra 13 tooth front sprocket and just switch out as you go between woods and the MX track/fast stuff. Only takes about 10 minutes to switch out.
Again, I think the ideal would be a 14/51 if you didn't want to change out the front sprocket.
Hope this helped.
- RCD :)
  • 426Hurricane
Posted June 06, 2005 - 04:55 PM
Thanks. Like I said, right now i am running 13/49, so when I buy the new set, (14/??) I will have a 13 available for switching out. I guess I could just get a 14 front and switch out between the 13/49 and the 14/49 for a while and see how it is. I will be needing a new set soon so I'll probably just pick up The Renthal set 14/50 w/R1 Gold chain.
  • 01yz426
Posted June 06, 2005 - 08:05 PM
I went from 14/49 to 14/48 for all of my riding.... Dunes/Track/Trail and I love it.... Woods will need a little more clutch work but love that top end, and my '01 already has loads of bottom end so I figured it wouldn't hurt....
  • 426Hurricane
Posted June 07, 2005 - 06:21 AM
Wow, 14/48, that must really pull! I couldnt imagine that in the woods I ride.
  • mx426
Posted June 07, 2005 - 09:20 AM
I was running a 14/53 on mine until I got the Rekluse clutch. Watch the chain guide on the rear of the arm if you go much bigger than a 52, it will have clearance problems.
  • Motoman_AZ
Posted June 07, 2005 - 02:56 PM
I have been switching between the 12/49, 13/49 and 14/49. I love the 14 when we are doing alot of open trails. I love the 12/49 for rocks, but ended up stripping the teeth off of the front gear with so much torque. The 14/49 works well with loose hills and some clutch. I have found the best all around, (if I can take Johnny gett'n the top end on me with his Honda) 13/49.
  • 426Hurricane
Posted June 11, 2005 - 06:52 PM
I just got home from the track and what a difference 1 tooth up front makes! I was running 13/49 and loved it in the woods but needed a little more on the track. I stuck a 14 up front and adjusted my suspension a little and I love it! I cant believe I rode on the track for the last month-and-a-half with a 13/49, the 14/49 is the ticket on the track for me. If i know i'll be in the woods that day, I'll throw the 13 back on.
  • Hot  47 replies
  • Hot  36 replies
  • On Yesterday, 06:20 PM
Motocross
  • Hot  491 replies
