CRF150: stock vs "full power" needle?
7 replies to this topic
  • SFeCRF
Posted June 05, 2005 - 03:47 PM
I ordered the "Full power needle kit" (PN: 16012-KPT-921). This needle is noticeably fatter that the stock needle. Can someone who has experimented with both translate clip settings between them? I'm at high altitude (7000-9000'), and my stock clip is at 4h position. Plug looks good to me. What is the full power needle designed to do, and what would an "equivalent" clip setting be?
thanks.
  • redrider150f
Posted June 05, 2005 - 05:11 PM
good question beats me :) ask the honda dealer
  • Red_Rider04
Posted June 05, 2005 - 05:18 PM
thanks.
those are your new pilot/jet/needle.... It is to allow fine tuning for easier starting and more throttle control... What it does is adjust the fuel flow ratio...
  • Tubo
Posted June 05, 2005 - 05:19 PM
The full power needle kit uses a much larger needle jet which allows more fuel at the upper rpm ranges. It does nothing for low rpm power. I'm running the needle on my son's at the bottom clip (full rich) at sea level. The bike had a very noticeable hesitation at 1/2 to 3/4 throttle on any other setting.
If you're going to use the full power needle kit I would recommend also running a rev box (BBR is what's on my son's) to utilize the extra fuel ability of the larger needle jet.
  • Red_Rider04
Posted June 05, 2005 - 05:21 PM
I also believe White Brothers makes a Rev Box.. if you are more comfortable with their products or feel that the brand has a better reputation.... But BBR makes VERY good products :)
  • Hoffhaus119
Posted June 07, 2005 - 11:24 AM
The dude to hit in here about 150's is 2wheeltuner, he can help!!! and white bro's does make a rev box! We use it and it works pretty damn good! About another 2ooo rpm out of it!
  • bungus
Posted April 29, 2007 - 12:23 AM
contact powroll ask for Pat tell her the info elivation/aftermarket stuff and she will tell you exactly where to set it you may have to get a different main at your elivation proably a 108
  • cherrymx
Posted April 29, 2007 - 03:51 AM
CRF150F '04 - 800 ft elevation
I've got a partial power up mod on mine. pulled the snorkle and baffle, twin air filter, 115 main jet with stock needle and pilot jet. Problem is when I put the Power up needle in the engine bogs when you crack the throttle quickly. Tried all clip settings. Also have a size 45 pilot jet that I've tried in combination with both the power up needle and the stock needle. Same thing. Engine bogs when you crack the throttle too fast. I'd like to get the needle to work for me but I'm out of ideas.
CRF230 JETTING IS GIVING ME FITS! 55 on the Pilot! ? by quadmaster50
  • Hot  63 replies
CRF 230F 2.5 ST/254cc build w/Keihin PWK 28 Carb - Jetting/Tuning by Falcon 1
  • Hot  190 replies
CAM INFO FOR CRF230 by DeaconJames
  • Hot  38 replies
CRF230 Tapping Valves tic-a-tic-a-tic-a by Scrammer
  • Hot  44 replies
Honda CRF230L 2011 by Chris.GVS
Honda CRF230L 2011
  • 0 reviews
