someone please settle this......
7 replies to this topic
  • DevilishYZ450F
Posted June 04, 2005 - 12:46 PM
will the WR450 stator fit in the YZ if i use the WR flywheel also?? i want the lights but without spending the $1000+ for a aftermarket kit.
Posted June 04, 2005 - 03:22 PM
No.
The WR uses an "inside out" flywheel to accommodate the drive for the e-start. The stator mounts in the outer cover, and the WR ignition cover will not fit the YZ450F crankcase. You need an aftermarket solution for this one. :)
  • DevilishYZ450F
Posted June 04, 2005 - 03:46 PM
DANG IT! ok thanks
  • yzf450jack
Posted June 05, 2005 - 08:48 AM
Try here they will rewind your stator https://www.bajadesi...2.aspx?content= :)
  • Birdie426
Posted June 06, 2005 - 09:39 PM
What about using a non-happy button (WR400-426) stator and flywheel? Don't know if they will work...just kinda thinkin' out loud...
Posted June 06, 2005 - 09:48 PM
I don't think the 426 stuff will fit under the 450's rather compact ignition cover, and I don't think the 450 will fit a cover from any other YZF, but it might. The gaskets are different PN's....
  • bierfasser
Posted June 06, 2005 - 09:52 PM
all you have to get is a lighting coil from Moose Hard Parts, and an acerbis head light/tail light, spend right around 300 or so depeding on the bike. check that stuff out.
  • ncmountainman
Posted June 07, 2005 - 07:02 AM
it won't work anyway you look at it,the crank has a different taper on the wr(03-05)than the yz
  • On January 15, 2017
  • 10 replies
  • Hot  50 replies
