adjustable hot cams for 426
1 reply to this topic
  • the426master
Posted June 03, 2005 - 04:06 AM
I am considering getting a set of adjustable hot cams, they have adjustable sprokets on both intake and exhaust and tha exhaust is only $ 89.95 instead of $189.95 if you get the auto decompression and it's not even adjustable. I was woundering if any bodey has tried these. If you want to look at them go to www.hotcamsinc.com :)
  • Hamish
Posted June 04, 2005 - 02:57 AM
if all you want is the adjustability, try falicon cranks. They make a slotted sprocket kit for the 426.
Or if you have the tools, degree the stock cams up, work out where you want them and press the sprockets off and then back on again in the right position.
