problems with wr450
26 replies to this topic
  • metalmaster117
Posted June 02, 2005 - 07:10 AM
i want to know what problems people have had with there wr450. if you could answer with year and problem you had that would be awesome. i also know that every bike has it problems i just want to see which one the wr has. :) peace
  • Vibeguy
Posted June 02, 2005 - 07:23 AM
On the 04 and earlier bikes the decomp plug above the exhaust likes to blow out which not only makes an oil mess but can allow dirt into the camshaft area of the head. This is easily fixed by installing the TT decomp plug available through the TT store.
  • metalmaster117
Posted June 02, 2005 - 07:34 AM
about how much does it cost and how much maintence did you do on the your wr.
  • beakr
Posted June 02, 2005 - 05:15 PM
So far, the only problem I've had with mine is not enough time to ride!! :)
  • moach1
Posted June 02, 2005 - 06:46 PM
my 05 wr blew up. yamaha paid for parts. lost a lot of riding time.
  • metalmaster117
Posted June 04, 2005 - 04:46 PM
WAT in gods name were you doing that made your bike blow up. was it a manufature default?
  • freestyle250
Posted June 04, 2005 - 08:39 PM
The only problem I have with my '05 is that the graphics on the gas tank are peeling off from under the seat. The bike rules, has been very reliable and maintenance free so far.
  • moach1
Posted June 04, 2005 - 10:29 PM
they just said there wasn't any thing i could do. mechanic said yamaha basically wanted to keep it confidential. i guess i got a lemon!
  • The Duke of Prunes
Posted June 05, 2005 - 07:11 AM
04 wr450 no problems so far, only have about 125 miles on it
  • felb1973
Posted June 05, 2005 - 07:17 AM
I got about 400 miles on the 05 wr450 and the only thing I can tell is it gets a little hot. Gotta love that resivoir.
  • tomwr450f
Posted June 05, 2005 - 06:18 PM
no problems as of yet, unless i allow the wr to idle for 20 minutes to allow for cool down after riding. then it boils over or over heats, yes i'm a dumba**
  • luckyfly
Posted June 05, 2005 - 08:01 PM
WR450 '05 (AUS) done 250 miles with some teething problems. Main problem from picking it up from the dealer was an erratic idle after it warmed up. It also had a terrible throttle repsonse off idle, I put up with it until installing a JD jetting kit and it fixed all. Seems stock it's too lean, hence people noting they run hot! mine boiled on hills etc before now it doesn't.
Im not much of a mechanic and annoys me to know it was lean all that time running hot and stuffing the motor.
Chain hits the sub frame, look from opp side to chain through wheel.
All round happy with the bike now.
  • Titanium Fink
Posted June 05, 2005 - 09:05 PM
I have just passed a thousand miles on my O4 WR and still love it. My problem is that I seem to get mud around (and past) the front fork seals.
If you maintain the bike (change oil, lubricate components, etc..) it will last for years and years.
  • clark4131
Posted June 05, 2005 - 09:20 PM
300 miles on a my '05 and all is great. I finally got the jetting dialed in and it runs great...SC
  • Adrock
Posted June 05, 2005 - 09:38 PM
i have close to 1300 miles (dirt/street) on my 05 WR450 and not any problems. The best bike i have ever owned.
  • metalmaster117
Posted June 06, 2005 - 06:59 AM
ok i have gotten tons of great responces and obviously the wr450f is the best choice but i have two final questions
1. Is it green sticker in californa?
2. What do you people do for basic maintences like what do you do every so often miles? (oil reeds forks engine that kind of stuff.)
  • Gadsen
Posted June 06, 2005 - 07:34 AM
Got about 240 miles on my 04 WR450, zero troubles at all. Had a WR426 prior and it was trouble free also.
  • WGP
Posted June 06, 2005 - 07:36 AM
1) Yes, Green Sticker
2) Follow manual for maint, they built it :)
  • JTWR450
Posted June 06, 2005 - 08:14 AM
04 WR450 - no problems except a fork seal. Put some Shock Sox on the rig and have had no issues since. sweet rig
  • Texas4play
Posted June 06, 2005 - 08:20 AM
05 is GREEN sticker
Low maintenence. Change oil, check valves on occasion, clean AF, lube chain, normal everyday stuff that is AFTER you do free mods and tune it right.
