Help!!!!!!!!!!
4 replies to this topic
  • 02WR426Cali
Posted June 01, 2005 - 01:50 PM
I just cut the grey wire on my 02 and did everything I was suppose to do. I warmed it up and it was fine for about 1 minute and then all hell broke lose. Now if I move the throttle at all, it cuts out and makes a loud popping noise like a backfire. What the heck happend, I thought it was supposed to make it run better?
  • drewpeacock
Posted June 01, 2005 - 02:59 PM
Is the Hot Start pulled out.
  • 02WR426Cali
Posted June 01, 2005 - 06:58 PM
No it's in.
  • the426master
Posted June 02, 2005 - 04:46 AM
all the gray wire does is change the ignition mapping
I don't see any way the gray wire being clipped would change it that drastically I would put a new spark plug in it and make sure you have fresh gas and don’t leave the choke pulled to long that will foul plugs you might clean the carb too
I clipped mine and it just changed the midrange to top end :)
  • 02WR426Cali
Posted June 02, 2005 - 06:24 AM
Thanks master. I'll give that a try and see what happens.
