05 wr 450 backfiring on deceleration?
11 replies to this topic
  • dmack
Posted June 01, 2005 - 12:39 PM
Hey guys, whats up with this thing backfiring on deceleration?
I have done all of the "free mods"
gray wire
throttle stop
snorkle
Is this normal, or how can I fix it.
Thanks
  • motojason
Posted June 01, 2005 - 12:53 PM
Remove the AIS. That will help to get rid of the lean condition in the exhaust that is causing the backfire. TT store has a good plug kit for sealing up the holes once the parts are removed.
  • dmack
Posted June 01, 2005 - 01:01 PM
thanks moto jason
what does the ais actually do?
and does it rob power ?
  • byggd
Posted June 01, 2005 - 01:45 PM
AIS Air Injection System aka smog pump. Yamaha added it for 05 450 to get it green stickered.
  • moach1
Posted June 01, 2005 - 06:30 PM
does not rob power. once i removed mine, no more popping. i think the ais removal kit is a must have!!
  • Fredneck75
Posted June 02, 2005 - 05:18 AM
Removing the AIS alone may not be enough. You will probably want to rejet to get it just right.
  • clark4131
Posted June 02, 2005 - 06:32 AM
For an '05, backfiring on deceleration is usually caused by one or a combination of the following:
  • AIS
  • Lean needle position
  • Lean fuel screw adjustment
  • Lean pilot circuit
  • Loose connections in the exhaust system
Check and adjust each of these individually and you'll figure it out...SC
  • cgrlvr35
Posted June 02, 2005 - 09:05 AM
Is that just for the California bikes purchased in that state? I bought mine in Oregon. Do you have a photo odf the AIS procedure?
  • farkawi
Posted June 02, 2005 - 09:32 AM
I'm at 5280' and mine still popped after AIS removal till I rejetted. I'm running a 50 pilot which is a bit rich (waiting for a 48) I raised the needle by inserting a .020" washer under the needle clip. You have to pop the aluminum plug outa the float bowl side to get access to the fuel screw which I'm running at 2-2 1/2 turns out.
  • clutchinoregon
Posted June 07, 2005 - 08:33 PM
what about the yz 450? ( 05 ) mine too has a little popping on decel. dealer told me normal... but id sure like to get rid of it
  • Dan_Lorenze
Posted June 08, 2005 - 06:54 AM
I'm not so sure I'd blame it on the AIS.. I would say there's a 90% chance your Pilot jet is too lean... All these "Free mods" will do very little without proper jetting specs... Go to the Jetting Database and see what we're all runnin... :)
  • motojason
Posted June 08, 2005 - 11:26 AM
Dan is right about it not being all related to the AIS. I meant do the AIS removal and then re-jet. I've got a JD kit and am using the settings recommended in the Jetting Database. Now my bike runs great!
