Small brake light for xr650r? any available?
8 replies to this topic
  • xdirtbikerx
Posted May 31, 2005 - 07:53 PM
I have a 01 xr650r with the baja designs street legal kit on it. its sweet exsept for the tail light. they use a nice light under the fender with a bracket for the license plate below it. only its to heavy, is there any kit or some way to convert the stock light on my bike to a dual filiment bulb? or if someone makes a replacement lens conversion. i would love to mount the license to the back top of the fender, and just use the stock tail light as a brake light/runing light. someone out there has got to know something about doing this. thanks, mike
  • Max Power
Posted May 31, 2005 - 08:22 PM
You mean like this :)
  • ponq
Posted May 31, 2005 - 08:36 PM
Yes like that :)
Is there a write up?
  • captb
Posted May 31, 2005 - 08:37 PM
I got a side marker bulb and socket at the auto parts and trimmed it down and piggybacked it on the existing stock bulb, works great, about 5 bucks. Had the same setup in my XR600Rs for years with the same bulb.
  • Max Power
Posted May 31, 2005 - 09:05 PM
Yes like that :D
No. But............ :D
I just jammed the B/D bulb and socket under the OEM lens.
And I did that with just 2 beer. Actually, you can still see the stainless fasteners...... the remnants of the original B/D install.
Sure I could go LED but I'm old fashioned. :)
As for the plate.... well......... :)
  • goblin127
Posted June 01, 2005 - 05:10 AM
Fourstrokes only sells a xr style brake light for 28 bucks. These people are hard to get a hold of but the light was worth it.
  • indy16
Posted June 01, 2005 - 05:23 AM
I have a 650L and wanted a smaller look too, so I bought an acerbis cover off of ebay. It had two 7w bulbs in it that were pretty useless.
I went to a bike shop and bought a set of dual filament blinker/ running lights for a sport bike, cannibalized it, fitted the dual filament socket into the acerbis cover and after a little tweaking it works.
I even fashioned a reflector / shield out of an aluminum can to help direct the light behind me. It also fives a little more protection against interior water since there isn't a good seal on the fender.
Hope it helps
  • xdirtbikerx
Posted June 01, 2005 - 07:57 AM
Awsome, this is a great web site! this is just the kind of info. i was hoping to get, thanks for the great ideas!, mike
  • KeithBoyd
Posted June 01, 2005 - 10:54 AM
Acerbis do one ....it uses two wee bulbs...one for braking and one for tail light....direct fit...soft opague plastic..not hard...try their website...I got one for €18.00....what ever that is in $.....
