I have just removed the theromstat
33 replies to this topic
  • redmanrandyed
Posted May 31, 2005 - 09:03 AM
I am wondering why on some 4 strokes (WR400's) there is no thermostat. If Yamaha does not run thermostats in the WR's then is it really going to harm the XR if you run it without?
I am currently running without one and the bike runs great, no overheating. Reading this thread has me wondering if I should throw one in though. :)
Posted May 31, 2005 - 12:46 PM
try the scott summers thermostat.
high compression
Posted August 23, 2005 - 03:47 PM
I Had The Same Issue With My Thermostat On My 2003 Xr650r. I Checked The Aftermarket Suzuki Swift Tstats And Found That The Prestone Brand That You Can Buy At Checker Auto Parts Is A Drop In Deal. Same Exact Size As The Old Original Honda Stat. Just Drill Your Bleed Hole On The Outer Ring And Your Set. The Napa Housing Was A Little To Big And The Guys At Autozone Here Were A Bunch Of Idiots!!!! Look Up Your Own Parts If Possible. Checker Has All The Tstats Out Front. Take Your Old Stat With You And Compare. I Was Really Surprised How Close The Prestone Stat Is To Original. Plus, The Bike Runs Much Better Now That It Operates At A Good Temp. Because All The Factory Stats Stick Open I Think The Factory Stat Is Wrong Temp (full Open At 94 Degrees).the Engineer Designed It That Way But It Can Always Be Better Right?
  • wr450fyamaha
Posted August 24, 2005 - 06:05 AM
do 1998xr650l's have theremostats?
  • frankstr
Posted August 24, 2005 - 06:18 AM
Yea, for the muffler bearing...... :D
  • wr450fyamaha
Posted August 24, 2005 - 06:39 AM
where is it located?
  • frankstr
Posted August 24, 2005 - 02:07 PM
Right next to the kanueter valve.......... :D
  • BrettJ
Posted August 24, 2005 - 02:41 PM
lol yeah just lift the voomdater clip and you should see it
  • wr450fyamaha
Posted August 24, 2005 - 07:11 PM
im serious, is there one?
  • Old_Man_Time
Posted August 24, 2005 - 07:19 PM
I ran without one for years on my first XR650R but I noticed in cold weather the bike ran different. I now run the napa thermastat which dropped right in. I drilled a hole in the outer ring of the thermostat and good to go. It has never over heated since I put it in. The only time I have ever overheated a 650 was before the power up kit was installed or when I abused the bike unreasonably. Meaning any bike would have overheated under such abuse, thermostat or not.
  • cholwerk
Posted August 24, 2005 - 08:15 PM
WR450 on your watercooled 650L there is a thermostat. If you are interested I have a few weet of Fallopian tubing I can sell you that will cure all your woes.
  • Naru
Posted August 24, 2005 - 08:39 PM
Just a piece of advice from someone who took the Napa route.
I purchased Napa thermostat #115 as stated on the XR650r.us website, drilled a bypass hole like the stock 'stat, and installed it. Took the bike out for it's first ride, and noticed it was running pretty hot. Got out away from camp, and the engine became way overheated (during night-time), with fluid bubbling even in the overflow bottle. We let it sit, then headed back home; on the way, white steam began rising from the engine because it got so hot. Finally got it home, and all of the fluid in the overflow bottle and all the fluid in the radiators sans ~1/4th of a cup had burnt off.
Later I found out the thermostat did not open at the proper temperature, or decently above it. Neither did the other one I bought for my other XR650R but never installed. The moral? I took both 'stats out and never turned back. If I was going to do it again though, I'd get the SRC one. It's just not worth saving $10 over the SRC 'stat to risk the quality control of your local auto parts store. Just my 2 cents.
  • don87xr600
Posted August 24, 2005 - 08:49 PM
Quit messing with him. It's next to the power band.
  • cholwerk
Posted August 25, 2005 - 06:02 PM
I have a couple of power bands I could sell two if the price was right. I modified the one from a KX500 to fix my pig. Man does it go.... :D lol.
Can anyone identify this xr600 piston? by ms_mtn24
  • 4 replies
1993 XR600R rebuild by ove
  • Hot  41 replies
  • Hot  32 replies
  • Hot  60 replies
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
