FCR Carb Power jet info
8 replies to this topic
  • nate22
Posted May 27, 2005 - 12:46 PM
Has any one had experience with running there bike with the tps power jet disconected? what are the resalts? Anny info would be greatly appreciated.
  • skthom2320
Posted May 28, 2005 - 06:35 AM
Whats a power jet?
The TPS just advances/retards the timing based on the throttle position. It has nothing to do with a jet.
  • nate22
Posted May 29, 2005 - 03:01 PM
Is the TPS located on the carb? is it the little electrical plug located on the carb? And I thought all the keihin carbs that come on the yzf 426-450 had a power jet or (accel pump) located in them, and that was what the little electrical plug was for. I was just wondering what the little electrical plug was there for.
  • skthom2320
Posted May 29, 2005 - 03:41 PM
OK - the electrical thing is the throttle position sensor or TPS.
I have never heard the accelerator pump referred to as a power jet before but, yes, all of the 426/450 used the accelerator pump.
I don't know of anyone who has disabled the AP on purpose. Plenty of people have limited the duration and amount that is sprayed.
  • nate22
Posted May 29, 2005 - 05:59 PM
O I see, I was wondering because I need to buy a new carb for my 450 and was looking at FCR cabs from differint stores and some did not include the TPS electrical plug for the ignition and were cheaper. I just wanted to know if it made a major difference. Thanks.
  • lumpy790
Posted May 30, 2005 - 06:40 AM
Why do you need to buy a new carb???
  • nate22
Posted May 30, 2005 - 12:57 PM
stolen
  • Anssi
Posted June 06, 2005 - 03:33 AM
The TPS is not required, in fact at least on the -03s many people (including me) have it disconnected.
  • sirthumpalot
Posted June 06, 2005 - 04:44 AM
stolen
Stolen carb? Unusual... Check out the Edlebrock offerings. I ride with YZFan and he picked one up for his YZ400F and said it was the best mod he ever did (search the posts by YZFan). He got it dirt cheap on eBay brand new, so maybe that's an option.
In regards to the TPS and accelerator pump; these two are completely separate. The TPS (electrical plug) deals only with the ignition, nothing to do with the accelerator pump. Some people disconnect it on purpose and it seems to run OK (search the threads here). I'm not sure if I would run without an accelerator pump; I believe you'll be looking at some serious bog issues if you get a carb without an accelerator pump.
