Pinched a tube
5 replies to this topic
  • 99raptor
Posted May 26, 2005 - 04:49 PM
Just pinched a tube on my 450 and was wondering what others run for PSI and the terrain you run in.
  • 2001YZF426Rider
Posted May 26, 2005 - 05:17 PM
13-15 psi, intermediatde to hard
  • 642MX
Posted May 26, 2005 - 05:41 PM
12-14 psi. Mostly slick hard packed - sun baked clay in southern Indiana.
  • flintlock28
Posted May 26, 2005 - 05:56 PM
I read on a website one time that the proper way to set tire pressure is to check your rims after riding, and look for the "rim clean" mark that is left after riding. What is meant by this is look where the inner part of the tire contacts the rim, and you will see an area that has been rubbed relatively clean as the tire flexes. This "rim clean" mark should be 4mm in width. If it is less, than lower the pressure slightly, and vice-versa if it's too wide. I asked a very experienced Hare-scramble winner, co-worker of mine about this method and he said Yes it's the most accurate way to check pressure, but few people do it. He said that all off-road tires are designed to flex in this manner, and you will see where the rim has rubbed off part of the dirt. Don
  • 00YZ426FMRCD
Posted May 26, 2005 - 06:37 PM
12-14PSI. Lower end for soft terrain.
  • deadeye1340
Posted May 27, 2005 - 12:35 AM
Flint, that's some good stuff, I think I'll try that!
  • On January 15, 2017
  • Hot  47 replies
  • 10 replies
