xr650r longer cables for higher bar mount?
6 replies to this topic
  • xdirtbikerx
Posted May 26, 2005 - 03:30 PM
Just bought a 01 xr 650r. love it, I am 6'2" and need the bars forward and higher. my only concern is if the cables are long enough stock or, am i going to have to get longer ones? appriciate any input, thanks.
  • jazzbrother
Posted May 26, 2005 - 05:17 PM
Try the XR650 forum.
  • Jeff_in_RC
Posted May 27, 2005 - 07:50 AM
If you need longer cables check with Terrycable. I had a longer set made for my XR400 when I went to taller bars and they are great. I put the new bars on my bike leaving the stock cables in place and measured how much longer I needed them to be and gave them a call.
Check this out, if they don't have them in their records you send them your stock cables for the dimensions and they will make you the new cables at 1/2 the cost, but you have to call them and talk to them first.
I got 2 of the 4 cables at 1/2 cost this way. I went with the decomp., clutch, and both throttle cables, the front brake cable/hose was fine. The new clutch cable is way smoother than the stock one and all of the cables fit great.
  • xdirtbikerx
Posted May 27, 2005 - 11:15 AM
thats awesome, thanks for that info. that is just the kind of info i was hoping someone would have, thanks again! mike.
  • Docmarkw
Posted May 27, 2005 - 09:27 PM
What was your total bill.
  • Docmarkw
Posted May 27, 2005 - 09:33 PM
Forgot to add, how much longer did you go over original cables and how high did you raise your bars.
  • Jeff_in_RC
Posted May 31, 2005 - 08:09 AM
Docmarkw,
OK, IIRC I went 2" on the clutch and throttle and 4" on the decomp and all for under $100.00. Not too bad in my book. On the bars I went with the Jimmy Button bars and no risers.
  • Hot  60 replies
  • 17 replies
Which thumper motor for a street tracker? by woz
  • Hot  29 replies
  • 7 replies
  • 3 replies
