What's the fattest tire i can use?
9 replies to this topic
  • HamBonE_23
Posted May 24, 2005 - 08:17 PM
I have an 01 Yam WR426. The rear tire is a 110/100/18. What is the fattest tire without having to do any mods that will fit?
  • tmonteton
Posted May 24, 2005 - 08:24 PM
I would think that a 120 would be fine
  • biznet1
Posted May 24, 2005 - 09:07 PM
The one that's on the fastest back wheel. :) Sorry, I had to go there.
  • devo1
Posted May 25, 2005 - 08:19 AM
send a pm to Indy wr450, he uses a terraflex , that is huge and fits.
  • speddie3
Posted May 25, 2005 - 02:06 PM
Please post up the results!!! And after seeing your size, the WR model's have smaller rear rims?? I say that because my YZ426 is wearing Dunlop 110/90/19 And my understanding of the numbers is width/sidewall ratio/rim correct??
Ham bone 23 do u have the stock rear rim??? My YZ has stock
  • twopumpthumper
Posted May 27, 2005 - 08:30 AM
I have a 2000 yz426 I went to a 18 inch rear wheel...stock is 19 inch, I run a 120/100/18 it fits fine, It is a little heavy though
  • HamBonE_23
Posted May 29, 2005 - 07:44 AM
I purchased the bike used. I just pulled up some info on Google and see that the bike origionally came from the factory with a 120/90/18.
So would a 120/100/18 fit???
  • clark4131
Posted May 29, 2005 - 07:35 PM
That's a taller tire, not wider. You'd have to go to a 130 for a wider contact patch...SC
  • Indy_WR450
Posted May 30, 2005 - 03:41 PM
TeraFlex 140/80-18 is the biggest tire you can put in but they dont make a 19" version so you have to replace the rim and spokes. :)
  • HamBonE_23
Posted June 01, 2005 - 11:30 AM
If the TeraFlex 140/80-18 is the biggest, what would be the best performance tire for a hard/inter track?
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  79 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
