Jetting question
4 replies to this topic
  • das_sey
Posted May 24, 2005 - 03:25 PM
Just got an 03 WR450 and it has the quick throttle bog. I have a JD jetting kit and am curious the settings. I am at sea level, 95+ degrees and high humidity. All the free mods have been done, the rest is stock.
Thanks
  • clark4131
Posted May 24, 2005 - 03:33 PM
Elevation 0 to 4,000. feet
30 to 45 degrees: 172 main, JD Blue #5, 48 Pilot, 2.0 turns, 75 starter jet, #0 leak jet
45 to 60 degrees: 170 main, JD Blue #4, 48 Pilot, 1.75 turns, 72 starter jet, #0 leak jet
60 to 75 degrees: 168 main, JD Blue #3 or JD Red #5, 48 Pilot, 1.5 turns, 70 starter jet, #40 leak jet
75 to 90 degrees: 165 main, JD Red #5, 48 Pilot, 1.25 turns, 68 starter jet, #50 leak jet
90 degrees plus: 160 main, JD Red #4, 45 Pilot, 2.0 turns, 65 starter jet, #60 leak jet
There you have it...SC
  • Indy_WR450
Posted May 24, 2005 - 03:48 PM
Those settings quoted above include high humidity regions of the midwest and south that require leaner jetting then dry hot California and Arizona type weather at the same temperatures. :)
  • das_sey
Posted May 25, 2005 - 03:57 AM
Thanks everyone for your help. I will give a try this weekend.
  • das_sey
Posted June 09, 2005 - 09:41 AM
Well guys, I still have not found time to look into my jetting issue, will be doing it tomorrow. I more question, where is the main jet located and how do you know what size it is. It is probably stamped on them, I just have not got out to look at it, wanted to find out beforehand.
Thanks again.
