WARNING stickers removal
15 replies to this topic
  • Brandon
Posted December 20, 2000 - 03:02 PM
I used a hair dryer to remove the dumb warning stickers on my new bike
but some of the sticker glue is still stuck to the fenders. What should i use to get this glue off without wrecking the fenders?
WR426 Power!
  • Ken
Posted December 20, 2000 - 04:05 PM
Easiest thing to get for removing sticker residue is nail polish remover. Be sure and get the original kind (with acetone). Haven't seen any problems of attacking the plastic.
  • s1031
Posted December 20, 2000 - 05:19 PM
Go to the hardware store and pick up a can of Goof off remover. This stuff works great.
  • MN_Kevin
Posted December 20, 2000 - 06:02 PM
Also "Goo-Gone" works.
  • Guest_Guest_*
Posted December 20, 2000 - 06:16 PM
I used gasket remover without ill effects. If you have this around the house it is good too.
tip: use it in a unconspicious area first just to be sure.
Darin from Missouri - 1999 WR 400F
  • aftershock
Posted December 20, 2000 - 08:07 PM
WD-40 works for me.
  • ande749
Posted December 21, 2000 - 03:42 AM
I noticed that a high pressure washer (or whatever it is called) removes those warning stickers nicely. Removes other stickers easily too, so caution is recommended, but you know this already.
[This message has been edited by ande749 (edited 12-21-2000).]
  • Dan_Lorenze
Posted December 21, 2000 - 06:41 AM
Brandon, I use a cleaner called "Citisolve". This stuff will take off all the goo in the world. Their are many imitations of this cleaner but none have worked like this one. Good luck, Dan
  • tige
Posted December 21, 2000 - 06:54 AM
gasoline works well
  • s1031
Posted December 21, 2000 - 08:00 AM
Gasoline does work well! Just add a match and no more sticker! Just a little Christmas humor. :) :D :D :D :D
  • Buck
Posted December 21, 2000 - 08:37 AM
I use brake parts cleaner. It works better than anything else I have tried.
  • Rich_in_Orlando
Posted December 21, 2000 - 11:15 AM
I agree wiuth Buck. Brakleen (in the red can) contains tetrachloroethylene. It will take off just about any normal adhesives. Use the stuff in well-ventilated area. It's not flammable but it is toxic.
  • Tige_Lamb
Posted December 21, 2000 - 01:04 PM
Who's this Tige member and where is he from,just wondering. Tige Lamb is my real name and I have only ever heard of one other Tige in 30 years.
  • Bryan
Posted December 21, 2000 - 01:14 PM
Maybe your talking to yourself?
  • Hick
Posted December 21, 2000 - 02:35 PM
Can’t you just check the I.P. Bryan?
I bet a lot of unregistered comments can be traced back to registered users.
  • Hayseed
Posted December 21, 2000 - 02:36 PM
I agree! :)
