How to change jet (03XR650R)
11 replies to this topic
  • honkylips
Posted May 23, 2005 - 01:08 PM
Anything to watch out for, or is it pretty self explanatory? It looks like you can access the jet without removing the carb or anything else?
  • JackAttack
Posted May 23, 2005 - 01:28 PM
Piece of cake. :)
I don't remember if it is the 400 or the 650, but there is a small white piece of plastic in the bottom of the bowl surrounding the main. That piece must go back in the right way and could fall outwithout notice if not careful. :D
  • BWB63
Posted May 23, 2005 - 02:52 PM
Piece of cake. :)
Yes, Yes, yes, been there. That is the XR400. The XR650R has a brass one.
  • GlocksRock
Posted May 23, 2005 - 05:08 PM
Hey I'm doing the uncorking right now on my 650r, I have put in the HRC needle and just have to do the main and pilot. Do you have to remove the 4 screws and the entire bowl or can you get to the jets through the 17mm (a guess) plug in the very bottom?
Thanks
  • frankstr
Posted May 23, 2005 - 06:31 PM
Hey, Glocksrock you need to take the bowl off to replace the pilot jet..
You can replace just the main thru the plug on the bottom of bowl...... :)
  • Max Power
Posted May 23, 2005 - 07:30 PM
Exactly.
  • GlocksRock
Posted May 23, 2005 - 09:04 PM
Great, more screws to possibly strip out. Do you also have to remove the larger screw holding the forked piece of metal? I only ask cause I attempted to remove it and began to strip the screw. It seems to really be in there. The smaller screws don't seem to be much of a problem. Why in the heck didn't they just use hex heads?
  • JackAttack
Posted May 23, 2005 - 09:16 PM
The best thing to do is grip the sides of the heads of the screws with a GOOD set of needle nose pliers, to get them started.
Go to ACE hardware and replace them with Allen screws. :)
:D
  • Desertskyy
Posted May 24, 2005 - 07:43 PM
As mentioned earlier replace them with Allen head screws. The one screw that you stripped out is real tough to get out. I used a small hammer type impact tool to get mine out.
Good luck
  • RJC
Posted May 25, 2005 - 05:31 PM
The link arm set screw head stripped out on mine. A pair of 6" needle nose vise grip pliers took care of that. I would think any kind of impact driver would be ill-advised on carb fasteners. You do have the manual, right? :)
  • GlocksRock
Posted May 25, 2005 - 07:21 PM
No, I don't have the manual yet.
I removed the 4 screws holding the float chamber and realized that the larger screw doesn't have to come out, so I just left it. None of the other screws gave me any troubles.
I finished up the uncorking, got it all put back together, and finally got a chance to take it out. Holy cow what a difference. Wasn't able to really test it out on my side streets, I should be able to stretch her legs this weekend.
  • JackAttack
Posted May 25, 2005 - 09:10 PM
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 4 replies
  • 9 replies
  • 17 replies
