XR650L Carb. Plastic
11 replies to this topic
  • crwmac
Posted May 23, 2005 - 06:38 AM
A friend and I that both just recently purchased XR650L’s installed the standard mods this past weekend; snorkel removed, K&N filter, #55 Pilot, #165 main, shimmed needle, and new Big Gun Exhaust complete system. The result was fantastic with excellent throttle response throughout the range.
I have a question about a difference we found between the two carburetors. One had the white plastic piece that fits over the main jet (shown in figure 10 of the 4-strokes.com instruction for this mod). The other carburetor did not have that piece at all. Both bikes run equally well. What is that plastic piece for, and is it needed? Of course there is concern that that piece may be required for some reason.
Mac
  • MrShred
Posted May 23, 2005 - 09:05 PM
I believe the white plastic piece is a baffle to control fuel sloshing around in the float bowl. Are you sure it didn't fall out of the second bike?
  • crwmac
Posted May 24, 2005 - 08:37 AM
No It was definately missing. I ordered a new one from the Honda Shop. Of course they wouldn't cover it under warrenty unlesse I ran it through service. Nahh, rather do it myself.
Thanks for the information!
Mac
[I]
  • jerry999er
Posted May 24, 2005 - 01:56 PM
where can i get the keihin jets i need for my 2000 xr650l
  • Hayden
Posted May 24, 2005 - 09:51 PM
Hit up your dealer. There only a couple of bucks a piece. Any dirt bike shop will have them too.
Hayden.
94 L
  • XR650L_Dave
Posted May 25, 2005 - 08:32 AM
www.bajadesigns.com
www.sudco.com
get the phone# off the website and call 'em- only way to get it done.
Make sure the pilot jet they send is the short one.
D
  • goblin127
Posted May 25, 2005 - 08:58 AM
since were on the subject,when i got my dj kit it had no pilot jet in the kit, so i went to my honda dealer and got a 55 pilot. I told them I wanted the short one, when i took the stock pilot jet out it is shorter than the new 55.Is this the right jet? thanx anyone!
  • crwmac
Posted May 25, 2005 - 10:49 AM
Same here. The stock one was shorter. It was below the level of the pilot housing in the carb. The new one came up flush with the housing as shown in the picture on 4strokes.com. I figured it was OK since it matched the picture. Mine runs fine but I am also interested to know if there is a potential problem.
XRL_Dave ??? How long is long???
Mac
  • XR650L_Dave
Posted May 26, 2005 - 08:22 AM
My long one was out to, or sticking a little out of, the pilot jet well. The stocker was well recessed in the well.
The long one seems to work OK, but be aware the slosh baffle can wiggle around and cover the jet. I trimmed my slosh baffle a little to make sure there wasn't an issue.
Took me a few days to find what was causing that little problem!
Dave
  • crwmac
Posted May 26, 2005 - 11:46 AM
Thanks Dave! I will check out the baffle as you suggest.
Mac
  • XR-Det
Posted May 26, 2005 - 03:05 PM
Dave
Hey Dave, what were your symptoms of it??? I recently have the problem that when I come from higher speeds and rpms to a quick stop that my idle goes way down and the engine dies. It doesn't do that very often and if it happens it starts right back up.
I was thinking to start looking/cleaning my carb and plug...
Det
  • XR650L_Dave
Posted May 27, 2005 - 08:19 AM
My prob. was only large throttle settings worked, stalled elsewhere.
But if it only covers it a little it'll change the jetting, so if you have the long jet, you need to trim or relieve the baffle to be sure that's not the problem.
Dave
  • 22 replies
  • 4 replies
  • 9 replies
  • Hot  29 replies
