Carb leaking in YZ450
3 replies to this topic
  • jbyo
Posted May 23, 2005 - 05:04 AM
Have an 03 YZ450, leaking from hose as soon as I turn the gas on. I cleaned some funk out the bottom of the bowl, thought that was the issue closed it back up, but still the same issue. What's the best way to get the carb out of the bike?, not much room to work with the cables still attached. Would like to give it a more complete cleaning with the compressor.
  • offrodeo
Posted May 23, 2005 - 10:21 AM
i think i might know your problem, follow the hose that leaks up to the bottom of the carb. If it is the one i am thinking about, there might be an allen head screw at the top of the hose, tighten that and it might stop your leak. When i was putting in my zip ty screw i messed with that and when i loosened it gas poored out the hose. good luck
  • curtains23
Posted May 23, 2005 - 12:20 PM
Check the float in the carb, that could wel be your problem, (its stuck down) try tapping the float chamber with a small hammer or screw driver if that fixes it replace the needle valve and seat..good luck
  • ovrrdrive
Posted May 23, 2005 - 06:10 PM
The fact that there was "funk" in the bowl makes me think the bowl is gummed up and just needs a good cleaning.
There's no "easy" way to remove the carb, but it is pretty easy to get it off. You just have to disconnect everything and it will pop right out.
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 5 replies
  • Hot  131 replies
  • 0 replies
  • Hot  36 replies
