Hot Pipe
4 replies to this topic
  • WRBIGBOY
Posted May 22, 2005 - 07:15 PM
I just bought a 2005WR and after the bike runs for about 5 minutes my header pipe is cherry red ? anybody know why.
  • pudadin
Posted May 22, 2005 - 07:27 PM
that is normal.....you should see it when it is dark out! :)
  • hontrx265r
Posted May 22, 2005 - 08:16 PM
Its not normal, your bike is too lean!
  • clark4131
Posted May 22, 2005 - 08:36 PM
Are you idling the bike with no air movement, or does it happen while you're moving? If you're sitting still it is normal. If you're moving, then you may be a bit lean. What's your jetting look like?...SC
  • tree77
Posted May 23, 2005 - 08:06 PM
I did a search for this very same "problem" awhile back. Everything I found pointed to "normal".
