??? 400 or 450 flywheel on 426 ???
1 reply to this topic
  • myoung
Posted May 19, 2005 - 11:29 PM
I'm in the process of getting the parts together that I need to put a light on my 2000 YZ426 and There's a TT brother selling a WR400 and a WR450 flywheel. Does anybody know if either of these could be used for the conversion? Will it be out of balance, will either work with a wr426 stator, or for that matter will either one even mount up to the 426 crank?
Another thing is if I have to use a 426 flywheel, the stator I have has a specific part number for a 2002 WR426 and Yamaha also shows different part numbers for an '01 WR426 and an '02 WR426 flywheel as well. Do I have to run the 2002 flywheel to 'match' the stator?
Any help would be greatly appreciated.
  • slotracer577
Posted May 21, 2005 - 06:13 AM
After owning a YZ 426, which I put a lighting coil on and a WR 450, the flywheels are not even close in construction. Just order a new stator for the YZ with a lighting coil and put it on.
John
