Water Wetter??
10 replies to this topic
  • snow
Posted May 19, 2005 - 01:53 PM
Anyone use the Redline water wetter? Is it any good or should i be looking for something else? Ran my bike up in the mountains and she seemed to get a little hot so I thought maybe some of that and my new rekluse and a little better gearing and i should be set. Also I just cleaned my air filter and I used some k&n filter oil and plastered the crap out of the outside and then sqeezed but there was not much exsess?? Also I just did the outside should i do the inside?
  • 02YZ426
Posted May 19, 2005 - 02:05 PM
Heres a recent thread about water wetter http://www.thumperta...ad.php?t=254928
  • snow
Posted May 19, 2005 - 02:11 PM
I should have done a search before I posted it sounds like this stuff realy works so I give it a try.
  • Slowmotion426
Posted May 19, 2005 - 08:19 PM
...I hear it's good... :)
  • jkrmz
Posted May 19, 2005 - 09:21 PM
Also try engine ice coolant. I ran it in my 426 and now in my rmz450 and it helped with coolant overflow
  • mx426
Posted May 19, 2005 - 09:34 PM
I like engine ice better myself, pre-mixed and I have had better luck with it.
  • crfdude86
Posted May 19, 2005 - 09:36 PM
i just switched to water wetter and its working good so far
  • Slowmotion426
Posted May 19, 2005 - 09:38 PM
.... :) .... :D
  • Ga426owner
Posted May 20, 2005 - 07:13 AM
I agree.....but both are good products for lowering temps - :)
  • DigilubeJay
Posted May 20, 2005 - 09:21 PM
Engine ice is a coolant. Basically Deionized water with propylene glycol added for anti-freeze. The glycol serves as a surfactant in the mix.
Water Wetter is simply and additive. It is a surfactant, or in simpler terms a soap.
It changes the surface tension of the fluid and allows it to dissipate heat more efficiently.
Truth be known, a clean water (DI, distilled) and a small amount of surfactant like Water Wetter is probably the coolest fluid you could possibly run. However, don't forget the freezing temps in winter.
I hate paying the outrageous price for Engine Ice, as it is a very simple formula that can easily be repeated for far less.
I use 50% distilled water(1.50$ gal.at the grocery) /50% propylene glycol (7-8$ a gal) and a couple capfuls of Water Wetter.
  • Fly-nBri
Posted May 21, 2005 - 05:42 AM
Engine Ice works great for me and has for years. 1 bottle will last a very long time so don't let the price get to you. Look around.....you'll find it cheap at some places. :)
  • On January 15, 2017
  • Hot  113 replies
  • Hot  36 replies
  • Hot  30 replies
