Rekluse auto clutch spacer?
4 replies to this topic
  • byggd
Posted May 19, 2005 - 08:17 AM
I saw a thread saying that a spacer is required but not included with the kit but the thread was from over a year ago plus I read that the clutch and be inproved (third gen?). Does anyone know if I will need a spacer to install the clutch on my 02 WR426? :)
  • Indy_WR450
Posted May 19, 2005 - 11:27 AM
You may need the larger diameter throw out ball spacer but you can get that anywhere to adjust your clutch idle engagement position along with the correct spring. :)
  • byggd
Posted May 19, 2005 - 12:35 PM
Thanks Indy I called Rekluse (side note it was sure nice to have someone answer that actually rides and not just some sales person) and he said if I order the kit and the purch adjuster I will be all he wrong? Where does the ball spacer go and why do I need a larger one? Does the spring that comes wiht the kit not work??
Sorry about all the questions just want to do the job once and correctly :)
  • Indy_WR450
Posted May 19, 2005 - 02:57 PM
You will be fine with the perch adjustor kit. Without the perch adjustor you woulsd need the larger spacer ball for proper position. I think the ball is not part of the kit but it allows you to set the cable slack to compensate for a smaller stock ball. I run the stock ball with my set up due to the cable length set up I am using. No problems! :)
  • byggd
Posted May 20, 2005 - 05:55 AM
Cool! Thanks for the info Indy. Should have it middle of next week, looking forward to trying it out! :)
