Front axle collar. Grooved or no grooves?
2 replies to this topic
  • 4mud
Posted May 17, 2005 - 04:06 AM
Need to replace front wheel bearings. I am going to get a machinist buddy to make me a new axle collar out of stainless steel. Are there any grooves in a new axle collar? My old one has a small groove 7mm from the end and a large groove 3mm from the end.
  • Hamish
Posted May 17, 2005 - 12:36 PM
no grooves. those grooves you see are from sand and grit getting under the seal lip and wearing the alloy spacer. Even though it is anodised, it doesnt last for ever. I need to do the same on my rear axle, just as well the bearings are sealed units.
  • AHRMA17L
Posted May 17, 2005 - 03:02 PM
The grooves are from wear. The aluminum is very soft and the seal will wear grooves in the spacer.
