I don't want to burn a hole in my pants...
7 replies to this topic
  • Bryan Bosch
Posted February 19, 2001 - 06:29 AM
If anyone has a stock headpipe off a 2001 WR/YZF, I'd be interested in buying it. It allows you to change your oil w/o loosening the pipe (way to go Yamaha) and includes the pipe guard the aftermarket pipes lack. I look forward to your replies.
  • Brad
Posted February 19, 2001 - 07:26 AM
You can give this a try:
http://cgi.ebay.com/...1703020&r=0&t=0
  • Scott_F
Posted February 19, 2001 - 07:31 AM
Bryan, I was able to prevent burns by making an aluminum heat shield. It was easy. Let me know if you want details.
  • Hick
Posted February 20, 2001 - 01:01 PM
I currently have header wrap on my PC T4 but the brush eventually unravels it at the header bend. I’ve been thinking about various ways to combat this, from low-tech Silver Bullet™ to medium-tech bent aluminum tubing.
So I’m interested in whatever ideas you have come up with Scott. Post ‘em here or send me an email.
burt@123mail.net
  • fershy
Posted February 20, 2001 - 01:08 PM
I plan on brazing up a couple nuts ( a la the stocker) to my Big Gun header and making a copy of the stock heat shield out of carbon fiber. With the higher bend of the Big Gun header it is more prone to damage from tip overs or drops. The Big Gun header does seem to tuck in better around the boot area though. Anyone running one of these like to comment?
fershy
  • Bill
Posted February 20, 2001 - 01:40 PM
On my 99, I run the White Bros tapered header. I haven't had any problems with torching my britches yet. I hope I don't :)
Bill
86TT225, 99WR, WR timing, throttle stop trimmed, air box lid removed, White Bros head pipe, silencer and air filter. Odometer and headlight removed. Moose hand and mud guards. YZ stock tank and IMS seat. Renthal Jimmy Button "highs" and Renthal Soft half waffle grips. AMA, SETRA.
  • Steve_Morgan
Posted February 21, 2001 - 12:14 PM
I was able to re-use my stock guard & mounting screws on my GYT-R header. Three 1.75" hose clamps, and three metric panel nuts, the type that clip onto sheetmetal. Run the panel nuts upside-down, with the clip part under each hose clamp. It takes a little fiddling to get the the alignment right, but it looks sharp when done. I turned the hose clamps screws under the pipe, so as not to be visible. About $2 worth of parts at the local hardware store. No more melted pants :)
  • Scott_F
Posted February 21, 2001 - 09:07 PM
Steve, very clever. Wish I had thought of it. Fortunately, Yoshimura is now putting heat shield mounts on their pipes.
Hick, I made it out of perforated aluminum, and attached it with safety wire. It was very light and effective. I rolled it into a half tube, about 6-8" long. Then I cut narrow v-slots about 1" apart to curve it in the front. You could buy some aluminum and form your own.
Scott F
