Re-Jetting w/ Aftermarket Exhaust?
9 replies to this topic
  • 913YZ426MXer
Posted May 16, 2005 - 09:41 AM
Machine: '01 YZ426F
Exhaust: Dr. Z (Header & Silencer)
Jetting: Factory
Performance: Could be better :D
I have heard that using aftermarket exhaust it is necessary (recommended) to re-jet? Truth to this? If so, please provide some suggestions. I have research FMF, K&N, and couple other manufactures that have jetting capabilities. .
Help needed! :)
Thanks!
  • MotoGoalie
Posted May 16, 2005 - 10:11 AM
You do a search. I don't have time. :)
  • 913YZ426MXer
Posted May 16, 2005 - 10:19 AM
I take it you have no suggestions.........thanks for nothing! :D
Thougts, ideas, suggestions, that's all.
  • MotoGoalie
Posted May 16, 2005 - 10:24 AM
I take it you have no suggestions.........thanks for nothing! :)
http://www.thumperta...searchid=370823
Pipe, rejetting.....YZ400/426/450 forum.
You want me to read through them now, or can you handle that? :D
  • 913YZ426MXer
Posted May 16, 2005 - 10:42 AM
Temper, Temper! Easy on the Throttle MG. I will take your suggestions and use them as needed. Now was that so hard.
  • MotoGoalie
Posted May 16, 2005 - 11:09 AM
Don't be like a CRF tard. Learn to use the search function son.
  • yz007f
Posted May 16, 2005 - 05:38 PM
On the dyno my Ti4 pipe leaned out the mid alot. You may want to try and richen up your needle and main. It really depends on your riding conditions. My bike is still fat 2-3 sizes on the main according to the dyno. But I'm a mx racer and it doesn't see alot of WOT for long periods of time. It does but not long enough for the main to be effective. Fatten it up and you will see.
yz007f
  • Ga426owner
Posted May 17, 2005 - 06:35 AM
Machine: '01 YZ426F
Jetting: Factory
Help needed! :)
Thanks!
I assume you mean DRD pipe - I had this combo on my old 01
raise or lower the clip on the needle - and go richer or leaner on the main with temp settings above or below 55.....
  • 913YZ426MXer
Posted May 17, 2005 - 08:29 AM
DR. D is correct! I may have to go leaner, simply due to the fact that my last fouled plug was black. Does this mean lowering the clip to gain a leaner burn?
Thanks for the help.
  • 913YZ426MXer
Posted May 17, 2005 - 08:30 AM
Help was on the way and oddly enough without the attitude.
Thanks for your help.
  • Hot  36 replies
  • 0 replies
  • Hot  50 replies
  • 10 replies
