01 WR426 forks same as YZ426?
3 replies to this topic
  • Hamish
Posted May 14, 2005 - 08:02 PM
Normally I get my forks done by suspension dude but the head rebuild has emptied the piggy bank so I'm doing it myself this time.
I have the 01 YZ426 workshop manual. Are the specs the same for the WR and YZ forks? What weight oil are you guys using? Roughly how much oil do I need per fork leg? The manual specifies height, not volume.
Thanks guys.
  • Chris_from_Oz
Posted May 15, 2005 - 12:14 AM
As far as I know, apart from the fork spring rate, YZ426 and WR426 forks are the same. I used 10w oil. I agree it is annoying how the manual specifies oil height, not cc's of oil, but if you just measure as directed in the manual, you should be right. :)
  • Hamish
Posted May 15, 2005 - 12:34 AM
Chris, the reason I was asking is to determine how many 500ml bottles I need to buy to do the job.
thanks
  • Chris_from_Oz
Posted May 16, 2005 - 05:16 AM
thanks
If your forks are bone dry, you'll need 3 500ml bottles from memory. I seem to recall needing just a tad over a litre (100-200ml's) for mine. It's been a while since I did it, but i'm certain that's right. I really need a workshop diary.....
