Front wheel bearing part#
9 replies to this topic
  • 4mud
Posted May 14, 2005 - 05:58 PM
Well it is time to replace front wheel bearings. I did a search looking for the best replacement bearings, there was a lot of discussion on brands but I didn't find any part#s for the non Yamaha bearing. If any knows the actual number of the bearing that they used it would be greatly appreciated. A sealed bearing seems like a good idea. Thanks for the help.
  • BEAN329
Posted May 14, 2005 - 07:03 PM
Definitley get a sealed bearing, I'm on my third set in the front :D
Think no balls or someone else makes a kit for the front wheel, seals and all.
I found sealed bearings from a local place made by KYK out of japan the bearing number is 6904RS. To me it is stupid not to have sealed bearings front and rear. :) Aslo do not negleck to chane your seals and collars if they are grooved to deep and do not seal as well.
  • 4mud
Posted May 15, 2005 - 04:47 AM
Thanks Bean329. Did have to buy the Yamaha seal or did you find a different brand? I am going to get a machinist friend to make me a collar out of stainless steel.
Anyone else have some part numbers? Maybe NTN or SKF. Thanks
  • banffboy
Posted May 15, 2005 - 06:01 AM
Pivot works or all balls make sealed kits
  • simon@vic
Posted May 15, 2005 - 08:29 AM
bearing #s are the same no matter who builds them. the #s indicate ID,OD, thickness, and "sealed-ness".
no need to order them form a motorcycle company unless they are cheaper. just grab them locally. look up bearings in your phone book. :)
  • Desracer
Posted May 15, 2005 - 10:05 PM
Call Rocky Mountain ATV in Utah ask about the All Balls bearing kits. I bought my kit their with both sealed bearings and wheel seals for way less than anyone local.
  • Wrbiker
Posted August 18, 2005 - 11:31 AM
:D
  • Cedric
Posted September 27, 2005 - 06:58 PM
Well I just went through this whole procedure, and it's a little more expensive than the usual situation. The yamaha parts are $17 each, and they have no seals. The local bearing shop wants $21 for an NTN dual sealed bearing, so I think I'll spend the extra to have the sealed bearings. Some of the other shops were quoting me $31 each for NTN parts.
After much internet searching, I found that a Blaster ATV has the same bearing on the inner front wheel, with seals. Might be a useful bit of information for somebody someday. I'm not sure of the $$ for that.
  • SJMC_DON
Posted September 27, 2005 - 07:34 PM
I just came in from my shop after front wheel bearings and seals. Go figure...... anyway, I would suggest e-bay. I got the rear set, (double sealed bearings with seals) for $18.00 + shipping and got the front set (double sealed bearings with seals) for $16.00 + shipping. I have one race on the rear set and they still seem tight :banghead:
When your on e-bay just type in " Yamaha WR450 wheel bearings" and the guy will pop up. Shipping was fast enough overall good deal I think :applause:
Good Luck!
  • e_dogg
Posted September 27, 2005 - 10:52 PM
Thanks for this guys.
