Does a K&S 12-0040 fit my 450?
5 replies to this topic
  • cgun
Posted May 14, 2005 - 05:11 PM
Will a K&S 12-0040 switch fit on my '05 WR450? I'm wondering if the kill switch and hot start lever will interfere with each other. Does anyone know of another switch that controls kill,horn,signals and lights that might be narrower?
  • cgun
Posted May 14, 2005 - 06:41 PM
Okay, I've been digging around all afternoon and found a good switch that Baja Designs uses. www.dual-star.com also uses this switch. It's 1/2" narrower than the K&S switch. Does anyone know who makes that switch?
  • 4mud
Posted May 15, 2005 - 04:43 AM
I use a switch assembly from a GasGas it is very narrow and has headlight off/low/high, signals, horn and kill switch. The feeds for each are separate so you can run the headlight/tail light/brake light from your AC and the horn and signals from your DC. I did make a spacer from a piece of 3/16 aluminum to provide clearance between the hot start lever and the kill switch.
The switch seems very durable since it was designed for an off-road motorcycle. Very pleased with this setup, it has worked flawlessly for me.
  • UltraHyper
Posted May 19, 2005 - 10:02 AM
I used that switch , had to mod the hot start by rising it about a 1/4 inch,i used a aluminum spacer ,and i disconnected the kill switch completely ,just use the ignition
  • SANG
Posted May 19, 2005 - 03:52 PM
The Switch Baja Designs Uses Is The Same One Gas Gas,tm,derbi And Most Euros Use You Can Order Them Through Your Local Dealer From Tucker Rocky Dist. Part # Is 05-9063 $59.95 Retail.
  • trailriderjoe
Posted May 19, 2005 - 04:27 PM
The K&S has a kill on it. So taking off the factory kill switch doesn't matter, it's gives you a little extra room. As far as the hot start mount, I haven't added my K&S yet, but it looks as if the 1/4 risers are the perfect idea. :)
