'01 426 Smoking
4 replies to this topic
  • Blue ARC
Posted May 13, 2005 - 11:23 AM
I had just put the 450 in a while a go and it works great. Well I shouldn't say that because I haven't had time to ride. I had the bike started 4-5 times and ripped in the field once since I had done the cam swap. Well today I go start it to make sure all is good for tomorrow. It ran fine but after about 10 seconds it started to smoke pretty good. :) It smoke for about 30sec then I shut it off just in case. The valves were fine the last time I started it :D . It had been sitting for about a month or so since the last time I started it.
Any ideas guys? :)
Thanks
Posted May 13, 2005 - 11:58 AM
Oil overfill?
  • mx537
Posted May 13, 2005 - 01:58 PM
You probably have a leaky valve guide which is not a big deal but when it sits for a long time oil will seep into to the cylinder and rest on the piston. let it idle for a few and if it quits that is what it is if it keeps smoking pretty bad you might check the rings.
  • Blue ARC
Posted May 14, 2005 - 09:39 AM
Well I started the bike again it smoked a little not as much as yesterday. I let it warm up and went around the yard. All seems to be fine. Now I have to check into valve guides.
Thanks
  • Hamish
Posted May 15, 2005 - 12:56 AM
it'll be your valve stem seals, not your guides. Doesnt sound like they are that bad, just ride it more :)
Next time you have the head off for inspection would be the time to replace them.
  • Hot  50 replies
  • Hot  28 replies
  • Hot  47 replies
