04 yz seat ?
4 replies to this topic
  • ncmountainman
Posted May 12, 2005 - 07:24 PM
i'm in the process of swapping parts between my old 04 wr 450 and my new 05yz 450 and found that i cannot exchange my tall seat from the wr,so i left the stocker on the yz. so my problem is that i put my 2.8 clarke on the yz (it accepts both yz/wr seats by changing the button position) and put the yz tank on the wr which will no longer accept my old wr seat. so i need a 04 yz seat,but the ? is does the seat on the 03-04 yz mount with the the 2 tabs under each side (as the wr does) or is it the same as the 05 which has one central tab? and if it is the 2 tabbed,does anyone have one thats for sale?
  • mikedabike
Posted May 12, 2005 - 08:39 PM
YZ450 seat has one tab. Same as the 05. I have an SDG tall on my YZ and it is way more confortable than stock.
  • Unibomber
Posted May 12, 2005 - 09:49 PM
If a train leaves New York at 6am.......Just Kidding
I have an '04 Yz450 with the Clarke 2.8 and all is well, my seat (which is too frickin thin) has a tab or bolt hole on each rear side sliding under the number plates. If thats what your talkin about.........And one central reciver slot in the front for the circle nut thingy on the tank..... :)
  • ovrrdrive
Posted May 13, 2005 - 12:36 AM
Whoa there man, you're getting way to technical for me here... :D
  • ncmountainman
Posted May 13, 2005 - 05:36 AM
thanx for the replies, sorry for the confusion. if any one could post a pic of the underside of they're 03-04 yz450 seat it might clear it up. the wr seat has the 2 bolt holes,then it has 2 tabs on each side that attach to 2 tabs on the subframe(where the 05 just has plastic knobs that rides on the subframe,and a single tab to the front),and then it has the "circle nut thingy on the tank" i think i can make it work by cutting the knobs off a yz seat(other wise i'd need a wr tank). UNIBOMBER did you save your old seat?
  • Hot  33 replies
  • 5 replies
  • Hot  36 replies
