5052 Alum vs. 6061 Alum skid plates
7 replies to this topic
  • ceetwarrior
Posted May 10, 2005 - 08:12 PM
Hey guys, I'm looking at two skid plates. One is 5052 3/16" thick aluminum for $60.00 and one is a DG 6061 .190? thick aluminum for $87.
What's the better deal? If the 5052 is plenty strong enough for the money then I'd go with that. But if the 6061 is way stronger for $27 is it worth it?
Thanks!
  • Dolce_Grappa
Posted May 11, 2005 - 01:26 PM
Doesn't you bike already have a glide plate? If not, I'd go with cheaper one.
  • ceetwarrior
Posted May 11, 2005 - 05:01 PM
Dolce, it's actually for my new YFZ but I figured I'd post in this forum to see if anyone better knew about aluminums.
I just need to know how big .190 is and what's the difference between 5052 and 6061 - just size or strength too?
  • Dolce_Grappa
Posted May 11, 2005 - 05:52 PM
Both are 3/16" thick, 6011 is stronger.
  • ceetwarrior
Posted May 11, 2005 - 06:09 PM
Dolce, thanks, are you postive?
Why do people measure in .190 when the average person doesn't have a clue what that relates to in inches?
Well, I think I'll save $27 and go with the cheaper plate if they are both 3/16" thick.
  • Buckwheat816
Posted May 12, 2005 - 09:47 AM
1/16"=.0625" 1/8"=.125" They are indeed the same thickness and should be tough enough. I would go with the one that offers the greater coverage. The 5052 may be a tad lighter.
  • ceetwarrior
Posted May 12, 2005 - 03:46 PM
Awesome, thanks Buckwheat. I'll go from there, that's all I needed.
  • stroker101
Posted May 12, 2005 - 07:46 PM
go with the $60 glide plate. plenty strong enough for what you should encounter. unless you plan on casing some large rocks. then you might want to double up on them... :)
